Results 1 to 8 of 8
Thread: Power steering and also bearing noise from front of engine??????
    99 VT Sedan
    Feb 2010
    Exclamation Power steering and also bearing noise from front of engine??????
    Hi all
    My car is leaking power steering Fluid
    I found the hose in question but i just need your advice if i need any o rings or anything els
    Its the hose that goes from pump to rack its the rubber hose that is cracked
    Also i have strange noise coming from front of engine....No it is not power steering noise
    Its sounds like a bearing is stuffed
    I have changed 3 idler pulley's and bearings , alternator and water pump...
    How do i check the other ones i have removed the belt all seems to be tight and they spins fine
    Is there another common noise other than the bearing stuff up and make noise???
    Any comments Welcome
    Thanks in advance
    Vx ss 2
    Nov 2010
    Narre Warren
    my ss had the same problem but all it was is the water pump bearing had some sideways movement and one of the idler pulleys was noisy. being an apprentice diesael mechanic i can pin point some stuff. could be power steering pump bearings. also bearings should spin freely not tight. with the power steering leak either cut the hose n re-use n replace the hose clamp or replace the hose n clamp again.mine had the same problems. all the best
    Rizzo
    .........Runnin' Wild...........
    ve sv6
    Aug 2010
    i take it the hose is the high pressure one(the one that screws into the pump and screws into the rack), if it has a crack it could be sucking in air and causing the system to airate causing the noise, i know you siad its not the pump but replace the hose before you change anything else just to be sure.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by Rizzo View Post
    Rizzo
    I just changed my waterpump on the weekend due to tiny tiny bit of movement side to side
    But after i fitted the new one had the exzact same thing tiny tiny bit of movement side to side
    when i took old water pump off it didn't have a spacer so i didn't install a spacer to new pump
    Its running around the middle of the waterpump pulley.....But do you or anyone els know if a spacer is needed 1996 vt v6 commodore
    As for the power steering i am getting my machanic to change this hose.....But he has forgoten little parts in the past....( I only use him as he is moblie,And i can watch him while i have a few beers)
    So he will be changeing the whole hose....Is there anything extra i should remind him about????
    O rings or anything els??????????????????
    Also regarding the powersteering bearing is this easy to change???? Whats involved in this task????
    Thanks for your help
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by glenn l View Post
    Yeh thats sounds like the hose...Anything els i should change while i change this hose...Anyextra things like o rings or anything els??
    99 VT Sedan
    Feb 2010
    Rizzo
    Do you think there is little chance a bearing inside the power steering pulley caused more stress on the power steering to result in a cracked hose?????
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    the belt itself could be causing the noise, did you change it when you did the water pump? Apparently they get noisy when they get coolant on them.
    I haven't lost my mind, it's backed up on tape somewhere
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by s_ikari2015 View Post
    I changed belt around 6 months ago
    At first i thought it was the belt but i sprayed wd40 on it same noise
    But its for sure some kind of bearing noise
    How would i find this noise for sure????
    I do know about the long handle screw driver test...But all the other pulleys the bolts move with the engine
    As the idler pulley can easy be checked as the middle bolt is a fixed bolt that doesn't move
    Thankyou all your help
  1. Power steering pump bearing noise
    By bendrinkwater1990 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2010, 02:00 PM
  2. Replace a Power Steering Bearing
    By CrimsonThunder in forum General
    Last Post: 13-02-2010, 05:09 PM
  3. front end noise. bearing??
    By calais24/7 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-10-2009, 08:36 PM
  4. vt ss front wheel bearing noise
    By rox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2008, 03:07 PM
  5. VT Front Bearing Noise
    By SteveB62 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2008, 02:09 PM
