so here it is...a/c compressor not kickin in..it works if i hotwire it from the battery..tried to check diode next to coil packs but it fell apart[heat???] relay works anyone out there got any ideas??? really dont want to get ripped off by techo again!!!
Maybe it needs a regas.The compressor wont run when the gas pressure is low.
Yup out of gas. You have a leak. TX valve wont let the compressor turn on if it sees insufficient pressure.
