Results 1 to 13 of 13
Thread: Clock springs, are they only available at Holden?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Default Clock springs, are they only available at Holden?
    I think I might be needing a new clock spring ( the dreaded air bag light) and I was wondering if anyone knows if they can be bought anywhere else apart from Holden? I want a new one and all the clock springs listed on ebay are second hand and I want something that will last for a while.
    I only buy from Holden if there is no alternative.
    MY RIDE
    feg
    feg is offline
    VT S S/C
    Jul 2006
    Not sure on where you get another one, but am interested to find out how much you pay for one. I take it you will be getting the one with steering controls?
    vs commodore
    Sep 2010
    wyongah,nsw
    yeh mate if u want one new u can only get them from holden i got one for my vt and was $220 the only other way is second hand
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by vs commo View Post
    I thought so, I got quoted the same price from Holden. For that price I'm tempted to go second hand. Thanks for the reply.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by feg View Post
    The $220 I was quoted today was for one suitable for audio controls.
    MY RIDE
    vic
    Nov 2010
    melb
    i work at wrecking yard and 3 wire clock spring would set u back about $40
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by aussiepride23 View Post
    Thanks for that. I've just got to make sure that is the problem first.
    MY RIDE
    VT Wagon
    Jan 2010
    I know you asked this ??? a few days ago.
    airbag light comming on could be a number of things. not just the clock spring.
    it could be the elec plugs for the seatbelt tensioners they get dirty and cause a fault.
    (more than likely the cause). a fault with 1 of the airbags, the airbag control mod (under the center consol) might be stuffed, If you recently changed your dash board or even had it out with the key on can cause the light to come on either way you will need to have the airbag fault code cleared with a tec 2.
    this is about $125.00 from holden. when they have the tec 2 conneceted it will tell them where the fault is.
    hope this helps
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Feraljay View Post
    hope this helps
    Thanks for the advice. I had a mechanic reset my airbag light but he forgot to take a note of the fault code. Anyway, I sort of suspected the clock spring because it is a very common fault. A few days after the light was reset I was turning sharply into a parking spot when the airbag light and chime came on again, this makes me suspect the clock spring even more. I will be going back to the mechanic and this time find out what the code is before resetting. He only charged me $10.
    MY RIDE
    VY Acclaim
    Aug 2006
    Quote Originally Posted by accentstencil View Post
    Thanks for the advice. I had a mechanic reset my airbag light but he forgot to take a not of the fault code. Anyway, I sort of suspected the clock spring because it is a very common fault. A few days after the light was reset I was turning sharply into a parking spot when the airbag light and chime came on again, this makes me suspect the clock spring even more. I will be going back to the mechanic and this time find out what the code is before resetting. He only charged me $10.
    WOW!
    Where is this mech who charged you $10 to get it reset?
    The light is on in my car and my mech told me it will be about $400 to change the clock spring, so thats a bit much...
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by BlackVY View Post
    WOW!
    It was at a transmission place in Campbelltown in Sydney, I was there for something else and he had just purchased a a scan tool so I guess it was all new to him so he only charged $10.
    $400 sounds a bit much, that's almost $200 for labour for an easy job, half an hour at most.
    MY RIDE
    VY Acclaim
    Aug 2006
    Cool.. thanks for that... I'll shop around...
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Got one you can have for $60 + postage that suits the steering audio controls.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  1. [SA] WTB: IRS SSL Springs Holden Vp Rears
    By reids22 in forum Swap / Wanted to Buy / Trade
    Last Post: 24-12-2009, 12:16 PM
  2. springs at holden...cheap
    By jas98 in forum The Pub
    Last Post: 31-08-2008, 10:31 PM
  3. Clock
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2006, 11:35 PM
  4. VN Clock
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 09:40 PM
