As its coming upto summer, im starting to use my climate control more, but when its on17 or C it blows warmish air, i was thinking it needs regasing, am i correct?
sounds like it, but be warned a simple regas isnt what normally happens, if there is no gas it probably has a leak which costs more, all i mean is, if you see a ad for regassing, take it on face value as it will normally cost you more
cause my heater tap blew the other day, the air con was freezing till then, in my old car it just ran out, so im hoping no leaks.
could be alot of things like stuffed compressor or a gas leak. and its impossible for it to run out of gas and just need a refill unless there is a leak
my old corolla had no leaks just no gas...
