Results 1 to 6 of 6
Thread: HELP! VT Berlina surging problem.
    VT Berlina
    Nov 2010
    Healesville
    Default HELP! VT Berlina surging problem.
    Hey all!
    Had this problem for over a month now and it's really ticking me off. Seems fine when running cold but once up to operating temp it will stuggle especially uphill, sort of hard to explain but say you'd be coasting along and go to accelerate the car will sort of hesitate and struggle to respond at times.
    It has recently had new leads, plugs, fuel pump, coil packs and dfi module but none of this has fixed the problem.
    It's getting new engine mounts next week, do they have anything to do with this kind of issue tho?
    Any help or suggestions on what to try next would be appriciated!
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    VT Berlina
    Nov 2010
    Healesville
    Like i said its hard describing, it's sort of both doesn't have the initial power, shudders, then i'll accelerated a bit harder and it'll take off like it should.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    if you put into gear with foot on brake
    and lightly accelerate does the car shudder? this is likely to be misfire then
    VT Berlina
    Nov 2010
    Healesville
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    right then...
    so when you are rolling along at low speeds and stomp the accelerator what happens exactly?
    do revs stay low like 2000rpm and it moves really slow or does it just revout and no go anywhere?
    also
    does it idle rough? e.g. does car shake alot?
  1. Surging Problem
    By inwiththenew in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2011, 06:21 PM
  2. Surging Problem
    By Ben3howard in forum General Discussion
    Last Post: 15-04-2009, 08:10 AM
  3. surging problem
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2008, 11:47 PM
  4. Problem with VK berlina
    By NoOzL in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-03-2007, 08:15 PM
  5. VS Berlina ABS Problem
    By Kevin in forum Electrical Wiring / Questions
    Last Post: 01-03-2005, 04:04 PM
