Results 1 to 3 of 3
Thread: how to replace the LH o2 sensor
    98 vt s pac
    Feb 2009
    Corowa NSW
    Default how to replace the LH o2 sensor
    ok i need to replace my LH o2 sensor i have the replacement one sitting here but i just need to know where to find the o2 sensor? and can i change it with out jacking up the car? (thought i'd be able to hire some ramps but nope)
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    You'll need to jack it up, is it for a the VT or VS?
    I'm guessing the VT I'll be in the exhaust pipe just before the cat, you can't miss it. Sticks out like dogs balls. Just use a shifter to undo it.
    98 vt s pac
    Feb 2009
    Corowa NSW
    yep i ended up finding it piss easy didn't have to jack the car up though if you turn the wheel hard it gives you enough room to reach under and undo it, only took about 5 mins max!
  1. How to replace tie rod end?
    By sweefu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2010, 10:11 PM
  2. VH heat sensor and petrol sensor!
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2009, 10:58 PM
  3. replace sensor on climate control VN
    By stackner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2009, 08:56 PM
  4. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  5. Guide Needed To Replace / Clean Throttle Position Sensor
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 10:21 PM
