Results 1 to 8 of 8
Thread: central locking wires???
    vt ss 5.7L
    Nov 2010
    Bathurst
    Default central locking wires???
    hi, i have a vt ss and im trying to wire up a auto window module to the central locking, can anyone please tell me what colour wires in the door are for this? and which is - and + ?? thanx
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Does this help.. I'm sure if you used the search button you would find more info.
    Attached Thumbnails Attached Thumbnails central locking wires???-central-locking.jpg
    Cheers,
    Dave
    vx custom 600RR
    Oct 2010
    i've just done this
    the best place to access the window loom and fit the module(under the rear air tubes) is under the console they all work the same cut power to the switch and feed the windows
    blue/yellow RHR up
    blue/red LHR up
    blue LHF up
    blue/white RHF UP
    the triggers are found in the drivers foot well and depending on how you want to trigger it you'll need to install a relay
    vt ss 5.7L
    Nov 2010
    Bathurst
    Thanx oska, i have done the wires for the windows but what colour wires are for the trigger? i have found 5 wires that go the door lock thingy but i dont know which ones to use thanx
    vx custom 600RR
    Oct 2010
    the brown/orange will give you a positive trigger
    it is best to wire a relay from that to give you a neg trigger
    so use it to power the relay pin 86, negative to pin 85 and 30 the connect the neg trigger from the window up to pin 87 of the relay
    hope it makes sense
    vt ss 5.7L
    Nov 2010
    Bathurst
    thanks guys im gunna give it a go on wednesday hopefully it will work cheers
    Supercharged VN Group A Commdore
    Mar 2012
    Charmhaven
    I just posted about this as all above info seemed wrong and didn't help me do my brother's VT.
    LIGHT GREEN/YELLOW STRIPE wire was negative trigger UNLOCK
    BROWN / WHITE STRIPE wire was negative trigger for LOCK
    These are accessible in driver's side kick panel and go up into the BCM. We pulled the plug out of the side of the BCM , soldered to these two wires, then plugged in back in. Works pefect.
    This was on a VT executive 6 cyl commodore.
    So again, it is NEGATIVE TRIGGER. light green wire with yellow stripe is UNLOCK, and the Brown wire with the white strip is the LOCK wire for central locking.
    DeanO
    Mar 2012
    Charmhaven
    Sorry, my post only valid for central locking, not for window module... Having said that... buggered if I could find the above info last week hence why I just posted it myself.
    DeanO
  1. Central Locking
    By havavb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2010, 07:20 PM
  2. vs central locking from one car into another
    By BRAWT_4TH in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 10:11 PM
  3. central locking
    By Pickle' in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 08:30 PM
  4. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  5. vp central locking
    By milesy69 in forum Electrical Wiring / Questions
    Last Post: 28-09-2007, 08:08 PM
