Hi
Does anyone know if the supercharger from the VTii S will bolt on to a standard 3.8L motor?
If you have all the other bits, ECU, harmonic, heads, injectors, LIM, extra pulleys and mounting brackets, blower to TB elbow, fuel rails and water piping. Yes it will fit, but the ECOTEC runs higher compression.
Far easier just buying a L67 complete and bolt it in.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
I have considered that...Any idea if they can still be bought new in WA?
wow, the badges on my car must be wrong then.....cause all mine says is "SUPERCHARGED" and then underneath that "V6".....no mention of ECOTEC at all.
They are different....stronger rods, lower compression and other bits and pieces. As Decicrate said, far easier to just buy an L67 and be done with it.
That's the same with our VX is says SUPERCHARGED and then under it is has V6 no mention of ECOTEC at all. We must of got ripped.
No where can I find reference of a Supercharged ECOTEC, the references given are usually L67 or simply Supercharged V6 Series I, II, III, which each have slightly different upgrades.
I am not sure of anything any more, I'm not sure that I even know what sure is, for sure for sure.
Hahaha, yeah I think Decicrate might know. 200rwhp is just letting an L67 breathe, nothing huge.
