Results 1 to 8 of 8
Thread: Traction control?????????????????
    vx
    Aug 2009
    Default Traction control?????????????????
    guys i was trying to revs the engine in park a couple of times and the low traction control light flicks.
    can some one tell me if its normal?????
    vx
    Aug 2009
    another question can someone tell me where is the location of the alternator regulator on VX COMMODORE plz?????
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I can't answer the first one, but I believe its not good for the transmission to rev it in Park, as the pump isn't turning at a high enough speed, and the torque converter will need the oil as its working way too hard. You torque converter stall speed is about 2000rpm I think, and revving it beyond that will kill it.
    The regulator is on the back of the alternator, it the black thing.
    Ronald Reagan (1986)
    vx
    Aug 2009
    thanks mate but for the first question how come that its gonna be bad to revs the engine above 2000rpm!!! then why did they make the rpm to be more then 7000rpm??????
    VX Berlina
    Apr 2007
    The torque converters job is basically the clutch of an auto, it allows the engine and gearbox to spin at different speeds, its also a torque multiplier. When the gearbox is in Park, than I believe the gearbox is locked, so the torque converter will have to absorb all the speed of the engine. When the car is in drive, the torque converter (which is basically a fluid coupling) will transfer the power to the gearbox and spin the box.
    Now like I said, the stall speed, which is the speed where the torque converter should be applying most of the power to the gearbox, is about ~2000rpm. Anything above this and your making the torque converter do something its definitely not designed too.
    Torque converters do absorb some of the engines power at all RPM, and that's why manual will always score better on a dyno. Though this is reduced a bit by the tuner 'locking-up' the converter. Your car also does this while your cruising, it will lock both sections of the torque converter together.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    the traction control light will come on at Rev limit ...
    rev limit is 5500 by memory, dont quote me on that lol
    the engine will give a little shudder when the light initially comes on too.
    all in all, not a good idea to do if you want to look after your engine/trans as a whole
    and im sure Acarmody knows a fair bit more about the Torque converter than myself, so in his words it will be doing damage to that also
    vx
    Aug 2009
    thanks for this information mate.
  1. stability control...traction control???
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-03-2011, 09:30 PM
  2. Vx ss ls1-abs & traction control lights stay on & traction control switch not work-
    By VTLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2011, 05:57 AM
  3. traction control????
    By pjwooly in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-03-2009, 07:45 PM
  4. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  5. traction control
    By trentsmith in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2005, 07:23 AM
