Results 1 to 16 of 16
Thread: 6spd gearbox oil change
    VT SS 5.7
    Mar 2005
    Goulburn
    Default 6spd gearbox oil change
    if manuals are anything liek autos, with worn old oil they are fine when cold and a nightmare when hot,
    anyways i was thinking since my gears are abit sticky after reaching running temp i would drop the oil and replace with quilty stuff
    how is it i drain the oil on this 6spd (gen3) and what good quilty oil should i use to refill?
    Real cars don't power the front wheels, they lift them
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    when i was looking at mine the other day im sure on a sticker it said to use A.T.F dexron 3 even though it is a manual?
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Transmax will be fine in a stock/near stock T56, or you can just use a quality Dex3 as GM say to use.
    vx
    Aug 2009
    am in the same boat. but am planning to do an ATF flush better then drop the pan and refill again coz you need to drain the old fluid which is still in the torque converter as-well. most of the trannys shops do drain and refill and they charge you between 150 to 188$. anyway its really easy to do it in drive way.first u need transmition kit for 30$ with any tranny brand fluid but dexron 3. now disconnect the supply hose at the bottom of the radiator and put an extension tube in it and then disconnect the return hose and put a pan underneath . take out the tranyys dipstick and put fresh oil in with engine running in (N) GEAR and look at the color of the fluid coming out from the extension hose once it turn red turn off the engine... remove pan and change gasket and filter .........that's it ur don enjoy....
    vx
    Aug 2009
    by the way u need at least 12 liters of trannys oil coz ur flushing otherwise if dropping pan and refill u need only 4.8ltrs....
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by rocket0000 View Post
    Thats all good but we are talking about manuals here not autos.
    vx
    Aug 2009
    i think in the owners manual it says that to refer to your Holden dealer if its manual...
    vx
    Aug 2009
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Yep thats what is says.Never done it myself was looking at it the other day till i read that to. But it cant be that hard there will be a drain an a filler hole. An on the box it says to use dexron 3 A.T.F but as wikky has said there are other brands you can use to.
    VX SS T56
    Feb 2006
    dex 3 automatic fluidis the right stuff.
    However you will find that a lot of people, including myself, use Transmax Z. I find it a lot better for shifting.
    If you have a look on the LS1 forum, there is a how to.
    The best practice is to fill the box up by removing the reverse plug switch and filling, it allows about an extra 500ml of oil in there compared to filling it through its normal filler. People find the extra oil can quiet them doen if they are noisey.
    It is an easy job, just need the right tools and also a manual oil pump to get the oil into the box. There is no room under there to pour straight from the container to the box.
    VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by Murdoch View Post
    Not quite correct. Best practice (recommended by Holden) is to fill the box from the filler plug on level ground until the oil just begins to run out the filler plug. Then replace the filler plug and put in another 500ml using the reverse plug switch.
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    I'd be going for some of the Penrite MGO70 - specially designed for the T56, rather than the Transmax Z, which is an auto trans fluid. Plenty have put the Penrite in now and the gearbox runs VERY smoothly, with a reduction in noise.
    cheers
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
    VT SS 5.7
    Mar 2005
    Goulburn
    Well i spoke to my local parts dealer he says DO NOT CHANGE FLUID, told me to call holden, asked the head mechanic up there ,they said DO NOT CHANGE FLUID, the car has just over 200,000k`s just wondering what it would hurt if i did changethe fluid?
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by madsav View Post
    Hey madsav did they give you a reason why you shouldnt change it ? I cant see why it would be a problem, they probably just want your coin.
  15. #15
    VT SS 5.7
    Mar 2005
    Goulburn
    Narr mate ,all they said was ,there is no need to change it, it stays like that for life.
    i kinda thought every 80,000-100,000k`s it would be good idea to change it out but now im abit confused lol
  16. #16
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    interesting so what thery are saying is manuals dont need a fluid change? i would change it anyway new fluid to me would be better than old fulid an i cant see it doing anything bad to your box unless you forget to refill it of course.
  1. vn gearbox change
    By geoff1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2010, 04:46 PM
  2. Oil for 6spd man gearbox???
    By KBone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2007, 11:12 PM
  3. vr gearbox change over to man
    By shoog in forum General
    Last Post: 03-02-2007, 10:53 PM
  4. VZ 6L 6spd gearbox noises
    By VZGEN4 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-07-2006, 02:43 PM
  5. v6 t5 gearbox oil change
    By s0sage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2005, 11:49 PM
