Results 1 to 3 of 3
Thread: 2002 vx commodore wont start plz help
    2002 vx commodore
    Nov 2010
    albanvale,vic
    Default 2002 vx commodore wont start plz help
    we have been having problems with our ignition for a while now...when u turn the key it would start but then go off instantly after a while we realised that if we lock the car and then unlock it would start but today we turned the key and something went click and now the car wont start and it is stuck on the middle bit so the warning lights and stuff are on....the key can turn but wont do anything has anyone had a similiar problem...would love some advice so i dont get ripped off by a dodgy mechanic....thanks selena
    vx custom 600RR
    Oct 2010
    check the key head contacts to the ignition barrel sometimes that can happen
    try giving them a clean
    vx s pack II
    Jan 2010
    aLKIDA
    If the car is not cranking over.
    Does the security light go off when the reds are on or when you try to start it.
    If its stays on there is a KEY/BCM communication error. The BCM activates the starter relay.
    Check the starter relay see if it works (swap it over with one that is identical).
    Check if there is power on the starter solenoid the trigger wire and the big power cable.
    You can bypass the starter relay by bridging pins 30/87 on the relay.
    Starter solenoid are common to burn out.
  1. Vh commodore wont start! need help!!
    By LiLi in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2010, 02:02 PM
  2. vn commodore wont start
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2010, 07:28 PM
  3. VR V6 Commodore wont start
    By BlueMonsta94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2009, 09:15 PM
  4. vt ss commodore wont start
    By steve67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2009, 08:26 PM
  5. vs commodore help..wont start
    By 21AZE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2006, 11:08 PM
Tags for this Thread
