Results 1 to 10 of 10
Thread: Alternator maybe :/
    Trav Man's Avatar
    Trav Man is offline Ya gotta love a V8 mate
    Black VX Berlina LS1
    Sep 2009
    Somewhere in this great southern land of OZ
    Default Alternator maybe :/
    I'm just after another opinion as yesterday the battery light flashed on the dash a couple of times but hasn't done it since.
    I'm thinking the alternator is on it's way out but not sure can you help maybe??
    By the way it's a VX Berlina LS1 Auto.
    Trav Man
    I do what I do, Not because I have to, Not because I want to, But because I can
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Take it to an auto sparky or battery seller, they can test both alternator and battery in about 1 minute and most don't charge.
    Ronald Reagan (1986)
    vx s pack II
    Jan 2010
    aLKIDA
    If you have a multimeter you can check the voltage output from the alternator.
    It should read between 13-14 volts. Also check the charge with a electrical load so turn the lights on and AC, wipers the voltage should be between 13-14 volts still. Also inspect the thick power cable from the battery to alternator make sure there is a tight connection on the alternator
    It sound like a intermittent fault.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Pfft you don't need a multimeter. Put your key in the ignition but don't turn it. Then press MODE and UP and hold them in. Now start the car and release the buttons. Keep pressing MODE until you get the alternator charge rate. You can keep this reading on as you drive around, simulate normal driving and make sure it stays relatively stable.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Sounds like your voltage regulator bushes might be worn. Unfortunately the regulator is not a separate unit like on earlier models so it can't just be easily replaced.
    vs commodore
    Sep 2010
    wyongah,nsw
    yeah id be check the main power wire on the back of the alternator is in good shape and not corroded
    VX Berlina
    Apr 2007
    Quote Originally Posted by Mick1988 View Post
    I have seen up to 1v difference between the dash and a multimeter read at the same time. No idea why, but I would always trust the multimeter.
    Dec 2009
    Quote Originally Posted by BlackVXGTS View Post
    You should be able to buy the brushes seperately and they are fairly easy to solder into the regulator. Just disconnect the battery and then take the regulator out and see how worn the brushes are, if they are any less than 5 to 6mm I'd try and replace them first and see what happens, they are only about $10 a set. Other than that as suggested check the power wire from the alternator and also check to make sure the battery terminals are clean and tight.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by wortus View Post
    On the v8 motor the regulator is internal in the alternator its not like the v6s were you can just unscrew them and replace.
    So you would need to dismantel the alternator to get to the reg.
LinkBacks (?)
  1. 19-05-2011, 09:51 AM
  1. VH 202 Alternator
    By NAY73N in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-05-2010, 04:03 PM
  2. Alternator fu&^ed
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2009, 10:10 PM
  3. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  4. Help: How to take alternator out
    By DVSWagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2007, 08:29 PM
  5. Looking for alternator for VT
    By VT97 in forum Swap / Wanted to Buy / Trade
    Last Post: 20-05-2006, 08:14 AM
