Results 1 to 9 of 9
Thread: VX Auto Trans lag/problem
    VX S Pack 01
    Sep 2009
    Mccrae, Victoria
    Unhappy VX Throttle Position sensor (sticking open)
    Was wayyy off the first time, did an error check!
    g'day fellas,i own a vx s pack 01 model thats auto with 210,000 on the clock, i lost my licence for a few months for being a naughty little vegemite, and in the 3 months its been sitting there i'd start it up every 2 weeks or so when i remembered,
    It drives along normal, takes off great, but when i slow right down to a stop, and let the idle slowly push me forward, it coughes and splutters
    Did the Error Check Test and It indicated My Throttle Position Sensor was sticking open? can anyone tell me exactly what this means! and how to fix it
    cheers, Tys
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VX S Pack 01
    Sep 2009
    Mccrae, Victoria
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    yeh change it to PWR mode over ECO and it will change the shift points. Which is what i was saying.
    VX S Pack 01
    Sep 2009
    Mccrae, Victoria
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    kinda need a bit more information then, have you checked for error codes? have you had the trans serviced? Fluid and filter change. Maybe you damaged something being a naughty little vegemite lol?
    Checking for error codes Checking error codes VT/VX
    VX S Pack 01
    Sep 2009
    Mccrae, Victoria
    well i went for quick drive, with the PWR button on, she behaves A+ very resposive and all is normal, i will check records when auto fluid was changed last (if i dont know how to do something i dont do it) does this indicate a fault ?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    the shift points may also be different when cold so have you tried also after the car is warmed up to normal operating temperature? Most holden manuals state to change the trans oil and filter every 80,000km
    VX S Pack 01
    Sep 2009
    Mccrae, Victoria
    well i cant find the book right now, it was warm when i first noticed the lag,
LinkBacks (?)
  1. Auto trans problem
    By jabba13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2010, 06:55 PM
  2. VR auto trans problem
    By muddyjunior in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2009, 12:25 PM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. VS Auto Trans Problem
    By Megawhats in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2006, 07:57 PM
  5. Vt v6 auto trans problem
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2006, 08:44 PM
Tags for this Thread
