Results 1 to 5 of 5
Thread: Coolant in valley, worth worrying about?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Default Coolant in valley, worth worrying about?
    While changing my intake manifold gaskets I saw this, not much but I guess it still shouldn't have been there. It was there last time I changed my gaskets too, so I don't think it was them.
    Should I worry about this much or not? I can't see any visible when I drop the oil. Nor can I see any oil or foam in my coolant.
    Ronald Reagan (1986)
    vs commodore
    Oct 2009
    Tamworth NSW
    Id say its run down there out of the inlet manifiold when you have lifted the manifold off. It probably did the same thing the last time you changed them too,which is why it was there last time.If it was leaking coolant like that while the engine was running the engine oil would get that white milky look about it.
    VX Berlina
    Apr 2007
    Oh good point, thanks for that.
    VP Exec
    Jun 2005
    You will, of course, be changing the engine oil after you have run the engine with the new gaskets to get the coolant contaminated oil into the sump?
    VX Berlina
    Apr 2007
    Of course, dropping oil tomorrow morning. The reason I changed the gasket is because its burning oil, but has only been happening since I changed my lifters, so thought maybe I screwed up these gaskets. Got some aluminum one from MACE, banged them in, and while I will need to change the oil and monitor it, it has solved my shitting RPM dropping problem (tries to stall when I come to a stop, and has stalled a few times. Auto BTW), and I think my fuel economy is better, but I will need a few weeks to verify this. So my guess is I had an air leak/gasket split in the old ones.
  1. Worrying noise!!!
    By My 03' VYII 'S' in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-11-2010, 11:03 PM
  2. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  3. can some one tell me where the valley is
    By bulldog79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 08:10 PM
  4. [Buick motor] Valley cover coolant leak
    By LeaThaL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2010, 10:30 AM
  5. 308 Coolant leaking into Valley
    By NZVK308 in forum V8 Development and Modification
    Last Post: 17-12-2009, 08:24 PM
