Results 1 to 24 of 24
Thread: got a port and polish
    Vy ss s2
    Nov 2010
    Townsville Queensland
    Default got a port and polish
    got a port and polish on my vt v6 the other day. with other mods its making 150.3 rwkw. feels awesome. just wondering how powerful some other n/a ecotec sixes are. and what mods have been done to achieve the output.
    TI3VOM's Avatar
    TI3VOM is online now VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    What have you also got done?? tell me yours and I'll tell you mine
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    Vy ss s2
    Nov 2010
    69mm throttle body, 12mm plenum spacer, pacemaker extractors, 2.5" custom bent single high flow cat back exhaust, otr cold air intake, full msd ignition, custom high ratio roller rockers, 105 pound valve springs, intake manifold and heads ported and polished. cant think of much more under the bonnet.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I achieved 145rwkw with a baby cam, raised compression, port and polish, CAI, extractors and exhaust, and tune of course. But I think my single ordinary cat exhaust is restrictive, also the lifters and pushrods with badly setup when it was being tuned and measured, as the engine stopped making power at 5400rpm when it should have gone up to the mid 6k in revs. I have since fixed the lifter problem but haven't got it re-dynoed.
    I can't see why your car would make 150rwkw with only that.
    Ronald Reagan (1986)
    Vy ss s2
    Nov 2010
    yer im in the process of a cam at the moment, still umming and uhhing you know. yer the standard computer can only be retuned so much, so cam and a computer are next on my list.
    VX Berlina
    Apr 2007
    Actually the stock ECU can be tuned A LOT, just got to find a decent tuner. Don't buy an aftermarket ECU, it will be a huge waste of money and still won't be as good as the factory computer.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Big E View Post
    all sounds good cept for the msd ignition, woulda been a good waste of money as there stuff isnt cheap
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Vy ss s2
    Nov 2010
    yer a wanted the aftermarket ecu to fully retune rather than use a chip when i get a supercharger kit. as for the msd price. i got it really cheap because i did pay a lot for it to begin with but 1 of the coil towers had a fault and they replaced all my ignition and gave me a full refund.
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    I've got:
    * NGK Iridium spark plugs.
    * Bosch motor sport racing leads.
    * Aunger CAI.
    * K&N panel filter.
    * Ported throttle body.
    * 9mm Throttle body spacer.
    * Port matched plenum chamber to T/B and Intake Manifold.
    * 7mm plenum spacer + 7mm more to come.
    * 12mm manifold spacer.
    * 1.9/1.95 ratio Roller Rockers 1.9 on intake and 1.95 on exhaust, soon to be reversed!
    * Pacemaker extractors tuned length design.
    * Soon to get twin 200CPI cats and custom Y piece.
    * 2.5" redback exhaust with rear resi removed.
    * Greenfoam tuned.
    Will be re-tuned after, swapping RR's around, getting cats installed, maybe putting on MSD ignition coils, and possibly getting the heads reconditioned also with a three angle valve grind, cleaning the bowls + larger valves.
    Haven't got it dyno'd yet but would like something in the end of around 180-190RWHP N/A, but would then like to take it to the strip
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Tuning the chip in a VT is not the only way to tune the computer, you can get a Kalmaker dyno tune, which has more tuning possibilities than most aftermarket ECU's but still uses the original ECU, which is a very sophisticated computer unit.
    VX Berlina
    Apr 2007
    Trust me here, the factory ECU can have a full retune done. The chip is where all the data is stored, so basically getting it chipped is the same as getting a whole new ECU. Don't waste money by replacing the factory ECU.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    I got msd coils on my vs biggest waste of 300 bucks lol did nothing, only looks good
    Vt Calais 50th Ann L67
    May 2010
    If you need to replace your coils use supercharged v6 ones. They have been proven to be as good if not better than msd ones.
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by Jarrodscv6 View Post
    When I inquired through my local dealer, they said that something was not compatible between the L67 and L36 coils.
  15. #15
    VX Berlina
    Apr 2007
    Really? I was under the impression they were exactly the same.
  16. #16
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by acarmody View Post
    So was I, they said something about the voltage not being the same or something like that!
    The guy then suggested to go stock L36 ones, when I inquired about MSD he said that every test he has ever seen has suggested that it will be a bit better than stock.
  17. #17
    VKCOMMO's Avatar
    VKCOMMO is online now Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Just out of curiosity, How much did your P&P set you back?
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  18. #18
    Vy ss s2
    Nov 2010
    just the port and polish alone. around $800 i think. i had other things done at the same time though so not 100% sure.
  19. #19
    Vy ss s2
    Nov 2010
    my vt is making 201.6 rwhp at the moment. by the sounds of it you will come very close if not more.
  20. #20
    VE S2 SV6
    Nov 2009
    Had mine dynoed. Got 133rwkw
    2.5" sureflo exhaust
    1.9 YT roller rockers
    24mm plenum spacer
    69mm throttle body
    lukey air filter
    type S CAI
    mail order tune
    Got some ported heads i need to get revalved. Then I want to install them. Should get me up around 150rwkw
  21. #21
    VT SS S2 A4
    Aug 2005
    Can it be tuned on the go? If your at the track and want to change something, can this be done with the factory ecu?
  22. #22
    VX Berlina
    Apr 2007
    Quote Originally Posted by rb26dett View Post
    I suppose if you had the right equipment.
    Quote Originally Posted by billy bob View Post
    24mm plenum spacer
    69mm throttle body
    lukey air filter
    type S CAI
    mail order tune
    I don't think your going to get 17rwkw from some ported heads. Maybe if you had a cam and raised compression to go with it.
  23. #23
    vt calais l67
    Jun 2009
    it can but u need thhe kalmaker software and realtime box then it can be realtime all the time .
  24. #24
    VS Super6 Utility 5 speed
    Aug 2005
    Cairns, Australia
    In the workshop rally car we've got Ported heads, valves, springs, modified intake manifold, Big cam and standard exhaust manifolds. Has a Vipec and makes 242hp at the wheels
    VN - VY V6 Kalmaker tuning.
  1. were can i get a port and polish done in vic
    By kalmar in forum V8 Development and Modification
    Last Post: 24-06-2009, 02:31 PM
  2. Port n Polish
    By Nzpure in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2008, 09:07 AM
  3. port and polish V6 heads?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2008, 06:33 PM
  4. port and polish?
    By harro_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 12:33 AM
  5. MAF port and polish
    By gen3_350_v8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-10-2005, 07:02 PM
