Results 1 to 22 of 22
Thread: Do NOT get a solid flywheel put in a manual VT
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Default Do NOT get a solid flywheel put in a manual VT
    That's it, never get one!
    Especially if you are after a car that sounds nice and does not sound like something is grinding and rattling inside your engine. The solid flywheel makes a terrible sound and ruins the tone of the exhaust.
    Yes you pay less for the solid, so if you're not after a nice sounding car - go for it!
    BUT...if you want your car to actually sound nice when going through the gears or driving slowly especially when going uphill, stick with the expensive dual mass flywheel.
    The dual mass has a dampener where as the solid does not, which causes the rattle. Unfortunatly I was not told by my mechanic that there would be a rattling noise with the solid so I am stuck with it as it's not worth spending $2200 on another clutch kit unless I'm going to keep the car for another 6 years.
    So that is my rant. Not really happy bit I just remind myself that it's just a car, it doesn't distinguish who i am as a person
    So I hope this has helped anyone looking at getting a new clutch kit/plate.
    Joe
    [url]www.cleangetaway.com.au[/url[
    Your Professional Car Detailer
    Commodore M6
    Jul 2010
    East Coast
    98 VT Executive
    Aug 2008
    Sunshine Coast
    well that was the price to get fitted. But I am pretty certain the dual mass kit is around $1,400, give or take $150.
    hahah, we are talking about Vt's, not the sexylicious R8's.
    Joe
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Fly wheel won't do that unless something is wrong.
    Dual mass fly wheels are fairly ordinary to drive with.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Sounds like a loose bolt or a cracked flex plate, makes a horrid sound at low speeds right?
    Best RPG ever
    3.8 VR Executive S2/ Kawasaki zxr250
    Aug 2008
    West Auckland NZ
    yea it should sound normal you better take it back to the mechanic and let them know maybe he never torqued the bolts properly and its come loose
    You dont want to be doing full rpm and the flywheel come flying off then youll be set back more than $2200
    Federation
    Against
    Rotary
    Tossers
    VT Calais
    Mar 2009
    SA - Victor Harbor
    sounds like nothing at all to do with a solid flywheel vs dual mass, just sounds like dodgy installation, take it back
    Nov 2008
    Smithton, Tasmania.
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Bought it, had it, no problems. The idea of going solid means that you'll only ever need to replace the clutch kit and machine the flywheel rather than replace the dual mass fly and buy the kit. Having the solid flywheel allows for the fact you wont lose as much power through the drive line (pending on what your pushing) as the dual mass provides a slight cushioning effect when engaged. It was put in place from factory to stop the sound of the gearbox as the getrags are alot louder than the t5's (VN VP VR manuals). My gearbox was loud, no problems with it at all. But it does depend on the car it goes into and its thrashed history as more thrashed will be louder than a baby'd gearbox. Although, you wont get the rattle sound above 1500rpm, only in high gears at low km/h.
    So basically if you want to get it for these reasons, get it. But be aware it will possibly be loud, so remember the title of this thread is not a guide. its just an opinion.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    VT Acclaim Wagon
    Oct 2008
    I'm with lufkin and soop. Solid flywheel can't make noise unless it is not installed correctly. there is nothing about it to rattle/grind and 2DIE, it does not have a flex plate, only autos do.
    A bolt left inside the bell housing would make that type of noise also. Possibly a clutch cover bolt?
    VS L67
    Sep 2007
    BrisVagus
    The dual mass flywheel is there to stop the GETRAG rattling its head off.
    If you put a solid flywheel in you WILL hear the gear box rattling, usually at idle with the clutch disengaged is when it is at its worse.
    When I did mine, I thought that I had put the flywheel on 180 out or left a few bolts loose. Note, some billet flywheels can be installed 180 out if not careful and a bit of force is used.
    With mine I did notice a bit more gear noise when in gear but, I had to really listen for it, at idle it was a shocker!
    Trouble with the dual mass is that if you are a bit of a sporty driver you may find you start to destroy them pretty quickly.
    Unfortunately a billet is the only way once you start to add HP.
    Its unfortunate that people don't get given the full story or don't do any research before making modifications, surely there would have to be a heap of threads on here about billet flywheels.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    Nov 2008
    Smithton, Tasmania.
    Could be a loose pressure plate. Which would be very poor indeed.
    People are getting too soft, "ehhhh it makes some noise, someone get the sand out of my vag"...
    (Not having a dig... just sarcasm)
    VT
    Apr 2005
    QLD
    I put a solid flywheel in my VT V6 and it sounded horrible.
    It kept making the noise and one day I power shifted into second and the engine exploded, causing an eathquake in China, killing millions of innocent children.
    Really, it was fine. No noisier than the dual mass set up.
    hendo93 is offline black license in 2 yrs!
    in a few years, vz ss :)
    Oct 2010
    casino,nsw
    [QUOTE=soop;1717136]
    i just fell off the couch lol!!
  15. #15
    98 VT Executive
    Aug 2008
    Sunshine Coast
    wow VT-565 that was a good call.
    And I have taken it back to two different mechanics on the sunshine coast.
    Ok guys well i really appreciate all your information, so thanks for that. I've had it checked by two different mechanics. First mechanic was the initial installer. They called up the suppliers and asked what's the go and apparently they are 'reknown to make noises'.
    The second mechanic I took it to, took the clutch kit out and did their research as well and were told pretty much the same thing, the only way to get rid of the noise is to get a dual mass.
    So rather getting a dual mass i got the solid plate shaved back a little. It has quietened down a tiny bit but it will come back i'm certain.
    $482 wasted.
    any other inputs?
    Joe
  16. #16
    98 VT Executive
    Aug 2008
    Sunshine Coast
    and yes you can hear a rattle when ideling with the cluch disengaged, it takes about a minute for the rattle come and it usually only comes when the engine is dead cold.
    Joe
  17. #17
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    Holden uses noisy boxes... no matter what flywheel and clutch you have. They're not very bright, and as Top Gear Australia said in their first series, take the engine from the Holden, bolt it up to the gearbox of the Ford and you'd have a perfect car.
    I haven't lost my mind, it's backed up on tape somewhere
  18. #18
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    I would suggest if the fly was balanced properly as an assembly with the clutch it would be a lot better.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  19. #19
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Sounds totally normal to me... both gearboxes can be noisey. As said losing the dual mass setup does away with the dampening so noises are inevitable. My mates who have Getrags, they have this really annoying whine constantly.
    I have had a few T5 backed cars now and all of them have to some degree had that rattle at idle, and personally i think its the imput shaft only when it's unloaded. You should hear the T5 behind my big cammed v6 at idle, sounds like it's fked!! lol. but runs perfectly fine.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  20. #20
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    I put an exedy HD Clutch and solid flywheel in my old VX. I don't recall and excessive rattle.
    Maybe it's different in each case and depends on how worn and loose your box is.
    And yeah I did...
    Sent from my HTC Magic
  21. #21
    98 VT Executive
    Aug 2008
    Sunshine Coast
    THanks for all the heads up guys. Really appreciate it.
    Just would like to close this forum stating that this was only my oppinion from what I have experienced.
    I am just over it now, not gonna let it get to me. But thanks again for all the help
    Cheers,
    Joe
    Joe
  22. #22
    vsspack's Avatar
    vsspack is offline King of the Mang
    VN Mang Machine
    Sep 2007
    Mildura
    Had a solid put in not long ago, Bit of a rattle at idle and little more jerky on take off but feels way more solid and much more reliable.
    Some say less talk more action. But I rekon more torque less traction!
  1. Clutch Kit for Solid Flywheel
    By uNEEk in forum GSL RallySport
    Last Post: 27-07-2011, 01:15 PM
  2. VZ alloytec solid flywheel conversion?
    By VzVzVz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-09-2010, 08:31 PM
  3. [TAS] vs-vy 5 speed getdrag solid flywheel (like new)
    By psivyv6 in forum Parts And Other Items For Sale
    Last Post: 22-09-2010, 10:29 AM
  4. VS V6 Ute 99 Manual - DMF to solid flywheel?
    By shasam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2010, 11:16 AM
Tags for this Thread
