Hi,
I have a VT wagon that I can't get the remote access to the central locking to work on. When a scan tool is plugged in, it will operate the doors, but then when I try & use my programmed remote/key, it won't work. Do I need to replace the BCM? Any thoughts would be greatly appreciated.
Sean
Flat key battery? Only thing I can suggest
Definitely a flat battery. if you have to come up really close to use the remote or if the remote randomly doesn't work then works again, definitely change batteries.
Is the scan tool showing that a signal is being received from the remote?
Silver Certified.
