Results 1 to 4 of 4
Thread: VT-VX Engine Wiring Harness
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Default VT-VX Engine Wiring Harness
    Hi All.
    On a vt/vx 4spd auto there is a small electronic control box located on the passenger side with the shifter linkage arm bolting through it. This has the provision for 2 seperate electrical plugs. I need to know what the bottom plug powers/controls.
    Cheers,
    Chris.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    reports back shifter position.
    is used on the later/higher models for the position lights on the instrument cluster.
    mwb235 Guest
    Yes it's for the PRND321 lights on the dash cluster, on VTII and VX Berlina/Calais and WH Statesman. All VT/VX auto models including VT series 1 - both V6 Ecotec and Supercharged engines, and the VT series 2 & onwards 5.7L V8's - have this socket on their transmissions. It was only on the VT series 1 that the PRND321 lights weren't connected up (i.e. a "plain" dash cluster fitted and plastic blanking cap on transmission socket/no wiring etc). This was because the old 5L V8 auto transmission didn't have such a socket so presumably Holden left this feature off the V6's so all VT series 1 models had the same features.
    It's an easy mod to do and no you don't need Tech2. I hooked mine up on my VT series 1 V6 Supercharged back in 2007. Other than fit a cluster with PRND321 lights (obviously!) all i had to do is fit 4 wires between that auto transmission socket and the PCM (using pins off a damaged harness). You put the wiring through the firewall (carefully drill a small hole through then fit a rubber grommet in firewall, on passenger side above footwell behind glovebox etc). The auto transmission plug is hard to find at wreckers because most engine harnesses are sold with the engine (see 2nd pic for what the plug looks like). It's made even harder because you need to find a Berlina/Calais/Statesman harness which are rarer & all the lower model harnesses are missing the transmission plug. But the PCM plug is easier as obviously all models have 'em - you just need to carefully lever out four pins out of the wrecked/damaged harness to re-use on your existing PCM harness. It's fiddly but not hard. Then you just slot these four pins into the corresponding pin cavities on your PCM plugs with a small "click" (pins E6, E7, E8 and F15 - see wiring diagram).
    Anyway i ended up finding an intact transmission plug on a wreck where there'd been an engine fire (so the engine and transmission were still in the car etc). I already had a spare old damaged VT Exec engine harness with intact PCM plugs.
    You could of course just swap the whole engine harness with another "PRND321" one, but there was no way i was going to that trouble (and significant cost!) for only four wires.
    For anyone interested in doing this mod, here are some wiring diagrams/pics that will help...
    (the last three wiring diagram pics may be too blurred to read due to forum file size limits - if anyone wants the full version just PM me your email address.)
    Attached Thumbnails Attached Thumbnails VT-VX Engine Wiring Harness-vtii-prnd321-wiring.jpg   VT-VX Engine Wiring Harness-vtii-vx-berlina-calais-prnd321-plug.jpg   VT-VX Engine Wiring Harness-vtii-prnd321-switch.jpg   VT-VX Engine Wiring Harness-prnd321-wiring-diagram-3.jpg   VT-VX Engine Wiring Harness-prnd321-wiring-diagram-2.jpg   VT-VX Engine Wiring Harness-prnd321-wiring-diagram-1.jpg
    Aug 2008
    NSW South Coast
    OK great! thanks for the quick replies. Much appreciated.
    PM Me For Details
  1. Vl Engine Wiring Harness
    By MA7789 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-08-2010, 10:41 PM
  2. wiring diagram for engine harness VB-VH V8 (Part II)
    By PanthaVS in forum Electrical Wiring / Questions
    Last Post: 29-11-2008, 02:48 AM
  3. VT Manual engine wiring harness & com
    By kaoscommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2008, 09:29 AM
  4. wiring diagram for engine harness VB-VH V8
    Last Post: 23-06-2008, 12:13 PM
  5. Wiring Harness
    By SinisterVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-05-2007, 11:28 AM
