can anyone tell me what this hose is in my VT v6
would take it out but its my only way of getting up the street to get a new one
it has a split in it and is spitting out steam (hence the duct tape)
sorry if its a bit big, and sideways haha
and also, would this hose have anything to do with my car overheating and my trans stufffin up?
or is my car just f*cked?
cheers lads
its a heater hose and with it leaking you will get losing coolant from your radiator and getting air in the system, replace it asap or risk major damage
is it an easy job?
Just take off hose clamps remove hose ,fit new one and tighten clamps . You might want to use a bit of lubricant on the ends of the hose so they slip on easier .
Also there are two heater hoses on your car , make sure you get the correct one . One hose has different size ends ( one bigger than the other ) and the other hose hasn't. Pretty sure the one that needs replacing on you car is the one with the different size ends . Make sure you top up and bleed the cooling system after changing the hose . Cheers ,Dave C
If nothing came outa the air bleed valve (on top of thermos stat housing, you didn't have the coolant level high enough in the coke bottle. You must have this level higher so the coolant will bleed out of the little valve screw.
Sometimes you may get an air lock around the thermostat when it is closed. To over come this and to speed things up, I have found if I fill radiator then fit the cap, then open the bleed valve and give the top hose a squeeze (expels air) then close valve and you will find the coolant level has dropped in radiator. Fill it up again and repeat the process, open, squeeze, close, fill, and eventually you will see coolant squrting out of valve when you squeeze the top hose.
also need to get the heater tap rredone too. that happened to me twice mate, then foudn out my radiator shat itself and had to get a new radiator...not fun...
