Results 1 to 10 of 10
Thread: fuel pressure regulator how hard to change
    98 vt s pac
    Feb 2009
    Corowa NSW
    Default fuel pressure regulator how hard to change
    just wondering how hard the fuel pressure regulator is to remove from a 99 vt, i've gone through everything else trying to work out why my car struggles to start and it's about all thats left
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is your fuel pump priming before start sounds a lot like when they dont prime and you have to get the oil pressure up so the oil pressure switch fuel pump backup turns on
    98 vt s pac
    Feb 2009
    Corowa NSW
    Quote Originally Posted by delcowizzid View Post
    yeah mate its priming its brand new, so is the fuel filter, the battery, reco'd engine has only been in for about 2 months has new rings, lifters & bearings. everytime i take it to a mech they tell me its something different, one did a fuel pressure test and said the fuel pressure dropped off to nothing as soon as the car was turned off, he reckoned that was my fuel pump but i put a new one in and it still doesn't start any better. I was thinking the fuel pressure regulator might have been why the fuel pressure dropped off so quick?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah probably mine sits at 40psi for ages when i turn it off.easy to replace its held in with 1 allen key i think.easiest way would be to remove the fuel rail to replace it but should be able to reach it in place
    98 vt s pac
    Feb 2009
    Corowa NSW
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    just picked up a new fuel pressure regulator from Holden today for $90. I have the same symptoms as you and have done the same things to try and fix it, so fingers crossed that this will fix it.
    Easiest to partially remove the fuel rail (don't have to disconnect fuel lines), might as well do the inlet manifold gasket while you are at it, which is what i'm doing.
    It is held in by a circlip, so circlip pliers will be very handy.
    98 vt s pac
    Feb 2009
    Corowa NSW
    Quote Originally Posted by jazza15 View Post
    how did you go, did it help at all? I'll be changing mine this week. I had to order one in through repco for $64, looks like its in a pain in the arse spot to get at too. OH anfd for anyone wondering its held in with one of those clip ring things
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    war
    war is offline
    VT
    Jan 2011
    SA
    Any updates on weather changing the fuel pressure regulator fixes starting problems?
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    it didn't fix mine If your car also coughs and splutters when you boot it (accelerate hard), then it could be your problem. It's back to the drawing board for me.
    As for Vt's having to replace the whole rail?? I thought all of them are removable?
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. Where to get a fuel pressure regulator?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2008, 08:49 AM
  3. fuel pressure regulator
    By mason_luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2007, 10:28 AM
  4. Fuel pressure regulator
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 10:19 AM
  5. Fuel Pressure Regulator
    By vl 88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-01-2007, 11:46 PM
