Results 1 to 7 of 7
Thread: 1998 Holden Commodore VT series 1 3.8L v6 No Spark Cranks But will not start
    1998 VT
    Mar 2010
    Exclamation 1998 Holden Commodore VT series 1 3.8L v6 No Spark Cranks But will not start
    I was driving around town and the car started to stumble and stall then it finally stalled one last time and hasn't started since, I tried to retrieve the fault codes by earthing pins 5 & 6 but the engine light just stays solid, I have also connected a usb data cable to my laptop and run efi live v4 to check for codes but it is not recording any codes, I have replaced the DFI module and tested the resistance of all the coils (they read at the required resistance) The next thing I am thinking of replacing is the PCM (powertrain control module) I am just worried that I am going to waist more time and money replacing the wrong things. What else could be causing a no spark situation? Please help I am at my wits end.
    Thanks
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    I was stumped years ago when one of my cars had a error code that isnt in the books, the car was stalling and half the time not even starting. Ended up just leaving it in the shed and walking everywhere cos it got so bad.
    Ended up being the ECU that shit its self. No error code for that.
    Best RPG ever
    vs commodore
    Oct 2009
    Tamworth NSW
    Id definitely try another ECU.You will need to get the ECU linked to the BCM (Body Control Module) with a tech 2 scantool.This can make the swapping over of the ECU's to see if its faulty,very expensive, as holden who mostly has the tech 2, charges anywhere from $40 up to $80 or more to do this..Im not sure if theres a way around it either so you can just test it..Some auto electrical places have these scantools too,so its worth calling around a heap of them places and going to the cheapest one..Even some holden dealer price differences can be huge,so try a few different ones of them as well.
    VT Acclaim Wagon
    Oct 2008
    Have you checked the harness connection into the base of the coil pack? They corrode or come loose = no spark. Even bent pins in them can cause this
    VT Calais
    Mar 2009
    SA - Victor Harbor
    1998 VT
    Mar 2010
    Quote Originally Posted by happileej View Post
    Thanks
    Problem Solved!!! "Hallelujah"
    It turns out it was just a damaged wire that runs from the crank angle censor to the dfi module took me about 5 minuts to fix.
    Unbelievable the car has been sitting there for over a month just for something so stupid, thanks for all thew help anyway.
  1. [NSW] Holden commodore v6 vt executive 1998 damaged
    By ma77es in forum Vehicles For Sale
    Last Post: 12-04-2010, 11:54 PM
  2. VT SS Cranks but no spark/wont start
    By heyman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2010, 12:35 AM
  3. 1998 Holden Commodore VT Supercharged V6
    By derjizm in forum VT - VX - VU - WH - V2
    Last Post: 10-10-2009, 04:45 PM
  4. FS 1998 Vs Commodore Series 3 Ute
    By timbo_001 in forum Parts And Other Items For Sale
    Last Post: 19-09-2005, 09:51 PM
Tags for this Thread
