Results 1 to 7 of 7
Thread: my thermofan runs constantly even when engine off
    Commodore M6
    Jul 2010
    East Coast
    Default my thermofan runs constantly even when engine off
    i left my car after driving home from work overnight and i noticed the thermofan was still running
    i thought it was just the hot weather
    next morning the battery was dead
    $130 later from repco i find the fan runs even with the engine is off
    otherwise car starts fine
    is the switch that turns on the fan dead?
    i have left the battery terminal off so it doesn't kill the battery and will drop it down to the mechanic on monday
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Either the low speed fan relay or the high speed fan relay could be stuck on. Try changing the relays around one at a time with another of the same type.
    MY RIDE
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Commodore M6
    Jul 2010
    East Coast
    thanks
    it's the little shitty things that piss you off
    i will need to get to the mechanic first thing... he's near a station but if he'll look at it right away i hope he can change the relay or sometihng
    i hate taking public transport
    this stuff sucks without a 2nd car... i've been driving my other one all weekend
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by TonyJZX View Post
    thanks
    The relays are in the engine bay and there should be a diagram under the cover that explains the fuses and relays. Just pull the relevant relay out and see if the fan stops, if so replace the relay. It will be much cheaper than a mechanic.
    MY RIDE
    '98 vt berlina
    Feb 2010
    happened to my vt before and it's only a stuck relay. it's a common problem and the relay is only about $10 from holden sparepart. easy to replace yourself.
    in the engine bay on the driver side, next to the battery there's the relay box. pull open the cover, and like accentstencil said, look under the cover to locate the fan relay. from memory it was dark blue in colour (the rest are black)? if the fan stopped when you pull the relay out, that's the problem relay.
    edit: the replacement relay i got was white in colour, tyco brand, just in case yours is one of these.
    edit 2: if you need to use the car, just remove the relay when you stopped. alot easier than removing and putting back the battery terminal
    vx custom 600RR
    Oct 2010
    as everyone said its the relay
  1. engine runs but no power
    By MARTYMAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2010, 06:08 PM
  2. Vk engine runs, then dies in reverse HELP :|
    By blinky666 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2010, 09:25 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. water/coolant in oil engine runs rough
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2009, 09:57 PM
  5. vn s1 thermofan not switching on
    By cameron20020 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2009, 08:29 PM
