Results 1 to 17 of 17
Thread: Aircon problem again, replaced the compressor by holden dealer and fail again ,HELP!!
    VT ACCLAIM
    Oct 2010
    adelaide
    Default Aircon problem again, replaced the compressor by holden dealer and fail again ,HELP!!
    Hi guys,
    Two weeks ago, I had my vt series 1 aircon compressor replaced by holden dealer(Metro Holden). and the compressor(brand new and after market ) cost me about 500 dollars, plus 300 dollars labor,and o ring ,regas etc. Then aircon works just fine, though not freezing air but cold air.
    Today, when I turned the A/C on, no cold air at all.
    I checked my compressor by swithching on and off A/C, I found out when A/C is on, the front part of the compressor is rotating and when A/C is off , the front part of the compressor stop rotating.
    But when A/C is on, the front part of the compressor is not rotating all the time, and it stopped after rotating say 5 seconds.
    Please help, Why aircon not working , bad compressor? What should I do when I see holden dearler?
    When he told me the compressor should be replaced, and he said the aftermarket one cost 500 bucks,and warranty only for the compressor , if it fails, I still need to pay the labor.
    VT ACCLAIM
    Oct 2010
    adelaide
    Oh, by the way, when turn A/C on, should the front part of the compressor start rotating or it suppose to just rotate few times and stop?
    cheers
    VT ACCLAIM
    Oct 2010
    adelaide
    I will definitely go to see holden dearler on Monday, could someone tell me why aircon not working and what should I say to the dealer to get the problem fixed,please.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id take it back to holden and get them to diagnose whether its a faulty compressor ,or if its something they have done while installing it.If it is the compressor thats faulty,get the holden dealer to write a quick note explaining that the compressor was faulty when they installed it,just in case you need to send it through to whoever you bought the compressor from.They should replace it for you under warranty...
    VT ACCLAIM
    Oct 2010
    adelaide
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jinxu_0 View Post
    cheers
    Yes it should. You might have a leak and that is why it is not working. The compressor clutch won't engage if it is low on refrigerant.
    MY RIDE
    VT ACCLAIM
    Oct 2010
    adelaide
    VT ACCLAIM
    Oct 2010
    adelaide
    Quote Originally Posted by accentstencil View Post
    when the front part stop rotating , i can see it want to rotate but it cannot, even when I stopped the engine, I can still see it want to rotate.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Sounds like your compressor is working properly. The front part should spin when you first start it but should stop after a while as the system pressure reaches a high enough point. There is a pressure switch on your reciever dryer that switches the compressor clutch on or off. If the compressor ran constantly then the air con core would ice up until it split open. One of the pipes going into the compressor should get really cold and start to ice up close to the compressor if it is working properly. You could have a problem with your heater controls or one of the flaps under the dash so the cold air is not getting to the vents.
    VT ACCLAIM
    Oct 2010
    adelaide
    VT ACCLAIM
    Oct 2010
    adelaide
    Default 5/12/10
    today the air con works just fine, and I am not sure what happened. But I will see them tomorrow to diagonise what the problem was any way.
    yes, the compressor is ok, I touch both hose coming from the compressor and one of them was very hot,and the other one was extremly cold.
    thanks
    '98 vt berlina
    Feb 2010
    why is a holden dealer uses aftermarket compressor??? and it sounded very dodgy when they only cover the part but not the labour??? i like to see any trader getting away with that
    when i replaced my compressor by a holden dealer here in melbourne it cost me about $800 as well but i wasn't told it was aftermarket. are they even allowed to use aftermarket part as a dealer?
    VT ACCLAIM
    Oct 2010
    adelaide
    When i asked them for prices,quotes,they told me a compressor cost about 800dollars.I ask them if they have cheaper one.later they told me they have found a aftermarket compressor 500dollars so 300 dollars cheaper.
    but if I wanted the aftermarket ,within the warranty period, if compressor failed,I would still need to pay the labor to get a new one fitted.
    Finally I decided to have the aftermarket compressor ,coz it's cheaper.
    And air con is fine now,not sure what happened but it failed one day,and back to normal .not sure if I still need to see them to check.
    VT ACCLAIM
    Oct 2010
    adelaide
    not sure if yours is aftermarket or not.because they told me a brand new not aftermarket,genial(he use this word not sur if i spell it correctly ,english not my first language)one cost 800and 300 labor
  15. #15
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The word he used would be genuine, which means real. Jut trying to help with your English.
    MY RIDE
  16. #16
    '98 vt berlina
    Feb 2010
    ok, just dug up my old receipt for your sake
    my was done in sep 2007, ie 3 yrs ago, in melbourne by holden dealer and the invoice details:
    code: 08gmzzzzcheck
    description: check operation of a/c system. checked and confirmed checked a/c compressor clutch operation all ok. checked found a/c system low on gas carried out a/c service. found a/c compressor not pumping gas. supplied and fitted new a/c compressor regassed rechecked all ok.
    amount: 177.00
    code: gm92102247
    description: compressor & cl
    unit: 1
    amount 535.50
    code: gm52455752
    description: seal ring a/c
    unit: 2
    amount: 9.70
    code: pol
    description: r134a air con gas
    amount: 50.00
    total: 772.20
    gst: 77.22
    total invoice: 849.40
    looks like a genuine compressor to me. and the labour was only $177 which include troubleshooting and fitting !!!
    btw i can't verify the air con anymore as i've already sold the car middle of the year......
  17. #17
    VT ACCLAIM
    Oct 2010
    adelaide
    Any way, it works fine now.
  1. VT aircon compressor dead
    By jinxu_0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-10-2010, 06:48 PM
  2. Vp Aircon compressor problems
    By Huntington in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2010, 02:21 AM
  3. Holden Dealer Problem your opinion wanted
    By LES2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2009, 05:07 PM
  4. WTB** VT VX Aircon Compressor
    By wwilde in forum Swap / Wanted to Buy / Trade
    Last Post: 14-02-2008, 09:45 PM
  5. F/S in SA, VN V6 aircon compressor
    By churnit in forum Parts And Other Items For Sale
    Last Post: 08-03-2007, 11:36 AM
