Results 1 to 4 of 4
Thread: Vibration noise from rear at 100 k's
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Default Vibration noise from rear at 100 k's
    Hi guys,
    I have a vibrating noise coming from my rear wheels when i go past a 100kph... Its gets worse and worse the faster i go. Its fine up to a 100kph and then it starts to vibrate...
    What could this be? Is it the diff or drive axles?
    Any advice is much appreciated....
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Check your tyres alignment and balancing, check the inside of the tyres and see if they are balding.
    VT Acclaim Wagon
    Oct 2008
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    brake rotors/discs could do with a machining, if not replacing with new pads. Mine's doing the same thing.
    Sometimes feels like it's coming through the steering but you still get the vibration through the entire car? Now, though, when I brake you really feel the shudder so I'd definitely say it's my problem there.
    I haven't lost my mind, it's backed up on tape somewhere
  1. Steering noise and vibration
    By 08sky_way in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2010, 02:12 PM
  2. VZ V6 ute noise and vibration
    By 2005vzute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-06-2010, 12:53 PM
  3. Vibration noise ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2008, 01:04 PM
  4. clunking noise and vibration
    By igs_rodino in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2008, 01:31 AM
  5. vibration noise on take off
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2007, 07:36 AM
