Hi guys,
I had a code 19 error in my vt today which the engine light was constantly on,
Then I had a major power loss on power which the engine did not rev up more than
1400 rpm on city gosh what an embarassing seen was....
I have replaced the TPS according to error was,indication TPS
Then I reset the engine disconnecting the battery which it did not restore the power
What should I do guys what do u reccomend?
Should I take it to holden I know they are gone charge me heaps...
Thanks,
Did you remove the throttle body before changing the TPS or did you change it with the throttle body still installed? Either way did you correctly install the "drive adapter"? The "drive adapter" is a plastic cover that loosely slides over the end of the throttle shaft, on the TP sensor side of the throttle body. It is captured in place when the TP sensor is in position on the throttle body. The drive adapter could fall from the throttle shaft after the TP sensor is removed. You need to ensure that the drive adapter is not lost.
