im after sc14 parts to fit a sc14 onto a vt ecotec, prefer crs type kit, mostly after pipe work to throttle body, brackets, clutch for a 5psi pulley as i have the pulley, and belt, and any infomation on how to set up would be great, running 5psi as to what belt size and way people ran the belts on a ecotec, where the 3 vacumm line on a sc14 goes, where to tee peice the blow off valve into, on 5psi do i need bigger injectors and a rising rate fuel pressure regulator
also its not going to be intercooled do i put the maf sensor after the bov ?
