Results 1 to 15 of 15
Thread: Someone tell me what is this area??????? Pic inculded
    vx
    Aug 2009
    Default Someone tell me what is this area??????? Pic inculded
    guys i have a little tiny bit of transmition fluid leak from this area and it does not drop on ground at all its stays up there. what should i do???? car is driving nicely no problems... i recently changed fluid and gasket filter as well but i also noticed the leak even before changing fluid. do you think it is from the screws coz lose or should i adjust them???? thanks...
    Attached Thumbnails Attached Thumbnails Someone tell me what is this area??????? Pic inculded-05122010077.jpg   Someone tell me what is this area??????? Pic inculded-05122010075.jpg
    vx
    Aug 2009
    by the way guys i tried to tie tend the bolts but couldn't reach them by a socket i need to take out the transmition mount. i tried wrench size 13-14-15-16-17-18-19 but didn't work...
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by rocket0000 View Post
    Probably because this is an American engine and transmission, so it will use imperial sizes.
    Ronald Reagan (1986)
    vx
    Aug 2009
    Quote Originally Posted by acarmody View Post
    you were so helpful mate thanks anyway....
    vx
    Aug 2009
    come on guys no one had seen this problem before!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! lollllllllllllllllllllllllllllllllllllllll
    VX Berlina
    Apr 2007
    Ease up champion, the thread is only a few hours old.
    That looks to me like the extension housing seal. Fairly common problem from what I can gather. I had mine fixed by a gearbox shop, was fairly cheap. Can't remember the exact price since it was a while ago, but I think I paid about ~$100 to fix it and to fit a corvette servo.
    VT Acclaim Wagon
    Oct 2008
    Have you tried wiping it off then watching to see if it comes back? I'm with acarmody, extension housing seal or the gasket between the box and extension housing. Just get in there with a decent open end spanner, probably 9/16 or near that, nip it up a bit and see if that does the trick. if not, new ext seal and gasket will probably fix it. Failing that, you may have a leaking pan gasket or porous case which allows fluid to seep out. both reasonably easy to fix.
    vx
    Aug 2009
    thanks for replying guys.... as i said i recently replaced gasket with filter and new trannys fluid and before i do that i noticed this leak as well............so i think its like u said (extension housing seal or the gasket between the box and extension housing). but man i tried hard to reach the bolts with a socket coz some said maybe the bolts are lose but couldn't at all. u should remove the trannys mount to reach bolts. i couldn't understand your way( nip it up). and yeah i did wiped it of once and it did came back....
    thanks
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    On a side related question...... Won't you have to rip out the engine and trany to replace that seal?
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    VX Berlina
    Apr 2007
    No because the extension housing is on the tailshaft end of the tranny, so you just have to move the tailshaft aside. Then its just held on by a few bolts.
    vx
    Aug 2009
    quick update i just took it to a specialist and he did lift the car up and check it he goes this is common in all commodores and its not necessary to do anything coz its a very tiny little leak not a big deal.... other wise he will replace the seal which gonna cost bout 155 as well. but guys i forget to ask him if he gonna replace the seal what bout the fluid???? is gonna be changed as-well????? upon replacing the seal will the fluid be dropped????
    VX Berlina
    Apr 2007
    I don't believe you have to change the fluid to replace the seal. Just let the car sit for a bit for the oil to drain back into the pan.
    vx
    Aug 2009
    vx
    Aug 2009
    mate is it easy to replace the seal in drive way or take it to a tranny shop??????????????
  15. #15
    VX Berlina
    Apr 2007
    I'm not 100% sure, I had mine done by a tranny shop.
  1. New Trading area changes
    By minux in forum Site Feedback / Site Problems
    Last Post: 24-12-2009, 06:24 PM
  2. Help Area?
    By ScoHar in forum Site Feedback / Site Problems
    Last Post: 09-06-2009, 03:11 PM
  3. New to Area
    By ianf in forum General
    Last Post: 11-03-2008, 03:58 PM
  4. For sale area?
    By ris00 in forum The Pub
    Last Post: 13-02-2007, 06:49 PM
  5. A new area maybe?
    By MBS206 in forum Site Feedback / Site Problems
    Last Post: 28-05-2006, 05:54 PM
