Results 1 to 13 of 13
Thread: Steering clunk
    VT Executive '98
    Oct 2009
    Default Steering clunk
    There is a clunking sound coming from the front end somewhere when I turn the car at slow to medium speeds. I've recently had the front struts replaced and also changed the sway bar link pins. I've bought new engine mounts which I plan on installing this week-end. Not sure if that will fix the problem. Any other suggestions would be greatly appreciated.
    D22 St-r Navara
    Dec 2010
    perth
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    VT Acclaim Wagon
    Oct 2008
    VT Calais
    Mar 2009
    SA - Victor Harbor
    my zbars needed new rubbers and my clunk went away, sounds similar to your problem
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    what sort of a sound does it sound like?
    Is it a tinny ting, or a grinding clunk.
    or does it sound like a spring uncoiling under pressure?
    Dec 2009
    Have you got someone there who can turn the steering wheel th elimit of the play while you look at the steering gear? I'd be looking at the coupling on the steering column where it bolts to the pinion on the rack and also the mesh adjustment on the steering rack itself. It needs to be adjusted with a torque wrench.
    Other things to look at are the tie rod ends. All this is easy to spot if you get under the car or look at the steering shaft from under the bonnet while someone turns the wheel the limit of the play.
    VT Executive '98
    Oct 2009
    Quote Originally Posted by wortus View Post
    I've got a mate coming over this weekend. I'll get under the car and get to turn the wheel full lock each way. Thanks for the suggestion. I had thought of tie rod ends.
    I had pedders change both my front struts about 2 months ago. The car has been making the noise for about a year. I'm a bit surprised that the mechanic didn't mention anything while he was under the car.
    VT Executive '98
    Oct 2009
    Quote Originally Posted by Krisp View Post
    did you tighten the strut links propperly?
    Yep. Followed the instructions. "Tighten until the bushes start to compress, then tighten 1-2 more turns.
    VT Executive '98
    Oct 2009
    Quote Originally Posted by graham7773 View Post
    Have you looked at your sway bar bushes? Worn, loose, cracked.
    No not yet. I'm trying to get a list of possibilities so I can at least narrow down where the problem might be. Can't check the sway bar bushes tonight, but will do this Saturday. Thanks.
    VT Executive '98
    Oct 2009
    Quote Originally Posted by Verynice View Post
    Could easily be tie rod ends or in the steering rack
    I'll have a look at these as well. Thanks.
    VT Executive '98
    Oct 2009
    Quote Originally Posted by lufkin View Post
    Now on the list of items to check. Thanks.
    VT Executive '98
    Oct 2009
    Quote Originally Posted by Rhin0o8 View Post
    It's kind of a thud sound. Not tinny and not grinding.
  1. clunk in steering - vr calais
    By pecksterism99 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2010, 03:32 PM
  2. 2004 VZ SS ute Steering clunk :S
    By madgamer2006 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2010, 09:22 AM
  3. VT Rear end Bump Steering & clunk???
    By GOTMYN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2009, 07:10 PM
  4. Vr Clunk, Help!!
    By raised_fist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 10:09 AM
  5. clunkity clunk clunk
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:30 AM
Tags for this Thread
