Results 1 to 15 of 15
Thread: Another instrument cluster question
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Default Another instrument cluster question
    I picked up a 3 window cluster today in perfect condition for $38 from the wreckers for my VX . I was wondering if it is possible to check to see how many kays it has done without having to pull out the old one and plug the new one in . Maybe some how make up a cable that you can plug into it and then connect to the battery.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Dayvo View Post
    I've made up a few "testers" from the main plug out of a wreck. Just run power from the battery to the plug and it fires up with the K's
    and 3 Dangerous non ABS VN's
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by 88GreenVN View Post
    Hey thanks for that , What color wires would i use from the main plug? Also i know this has been asked before ( with about 100 different answers ) but is it possible to change the Kays to match the old cluster ?
    Thanks in advance ,Dave
    88GreenVN's Avatar
    Jun 2006
    LOL - yes I can find the wires and post here. Some clusters can be progrmmed (white backed) some not. You may need to get it programmed to suit your car as well - air bags, climate control to name 2. You can ask questions (Rob) at Rob's Creative Calibrations
    VX 'S' S1
    Apr 2005
    South East,Victoria
    That would be nice if you could post or p.m me which wires to use to check the kays . The cluster i bought has the white back and was out of a VT Calais and is in mint condition . The only reason i bought a new cluster is because the odometer on my old one crapped itself and the readout only shows the first 3 digits unless it is a really hot day. How does the climate control affect the function of the cluster ?
    Thanks , Dave
    88GreenVN's Avatar
    Jun 2006
    Thanks , Dave
    The yellow black and grey to neg. The pink blue and the orange yellow to positive ( I forgot to write it down so I think this is correct). This should show the kms on the cluster.
    The level 3 cluster may need to be re programmed to suit the number of air bags in your car. Not sure if it needs to be changed if you have standard a/c instead of climate control. (I know my VZ needed to be changed)
    VX 'S' S1
    Apr 2005
    South East,Victoria
    88GreenVN's Avatar
    Jun 2006
    Make that black yellow (had it the wrong way around)
    VX 'S' S1
    Apr 2005
    South East,Victoria
    so thats black yellow and grey to neg and pink blue orange yellow to positive, yeah ?
    88GreenVN's Avatar
    Jun 2006
    Thats just what I put together in my shed and powered up the ODO - with lcd light.
    vt s pack
    Oct 2010
    brisbane
    not geting it programmed to suit ur car? will this casue problems with ur air bag going off?
    just changed to a lvl 3 dash and my airbag light comes on and beeps.
    reason i ask, holden want $160 to just run a code thought the car to check whats up
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    prolly better off using the 3 window cluster since u got it tho u can replace the LCD screen only 2 fix ur original cluster problem. Shane u should b able 2 supply them by now haha
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Ok i tried that and it worked , The ODO has 290000 kays on it . Thanks .
    88GreenVN's Avatar
    Jun 2006
    I have a VX L3 with 110,000 - but cant remember if it's for a V6 or V8.
  15. #15
    VX 'S' S1
    Apr 2005
    South East,Victoria
    My original one has 201000 kays so i will have to see if i can get the three window one changed to suit , plus get it reprogrammed as well
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. VE V6 Instrument Cluster
    By Andrew_Guppz in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-01-2010, 09:27 AM
  3. instrument cluster
    By vy low in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-01-2007, 03:21 AM
  4. Please Help - VT Instrument Cluster
    By Miss-E in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2006, 02:32 AM
  5. new Instrument cluster?
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2005, 04:02 PM
