Results 1 to 11 of 11
Thread: Aircon / Heater zone selector switch not working
    1997 VT Commodore Wagon
    Dec 2010
    Victoria Australia
    Default Aircon / Heater zone selector switch not working
    The selector for the zone control for the heater does not work. The selector turns but the aircon heat stays directed at the demist outlet on the window. It is a 1997 VT Commodore Wagon Series 1. Any advice on how to fix this problem appreciated or should I just take the car and a mortgage application to a holden dealer
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    There are two vacuum hoses that connect to a vacuum tank which is located on the passenger side of the HVAC (heating, ventilation, air conditioning) unit. One of these may have come loose. You may be able to access them by removing the glove box interior.
    Dec 2010
    Victoria Australia
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    Also check the vacuum hose on the back of the plenum chamber and the little round vacuum ball front driver side wheel well in front of the tyre ( in behind the gaurd liner ) an all hoses running to an from . An yep removeing the glove box reveals all
    Dec 2010
    Victoria Australia
    I have checked in behind the radio and found two small pistons which when moved manually shifted the airflows to each of the different zones but I could not find any vacuum hoses that appeared to be loose or have come off. Leading from the back of the switch were four wires two of each which went to the two piston type devices. Can someone tell me if I am in the ball park. And also how do you get to the vacuum tank is it neccesary to pull the whole dash off. Finally what is a Plenum chamber. Sorry for my ignorance but I was a champion at fixing my old HR.
    Dec 2010
    Victoria Australia
    I have rechecked it and have only found the one vacuum hose that runs of the heater through the floor should there be another if so where do I need to look.
    Dec 2010
    Victoria Australia
    TZB
    TZB is offline
    VE SV6
    Jan 2008
    Hi Crowee. Did you ever get to the bottom of this? My missues VT has the exact same problem.
    Dec 2010
    Victoria Australia
    Yeah in the end I gave up and took it to the dealer service centre. It was pretty much as everyone said a leak in the vacuum hose which they replaced and it has worked fine ever since. Crowee
    lion_g is offline LionG
    VT Executive Series II 3.8/V6
    Jun 2009
    T'Ville
    VT 5.0L SS, Manual
    Mar 2012
    NSW
    AHHHH I wish this thread had pics and a result.... I have the exact same issue on my VT SS.
  1. Demister-Aircon Heater Blower Not working
    By stuballs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2008, 07:43 PM
  2. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  3. Heater Selector thingy isn't working...How do I fix it?
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2006, 11:08 PM
  4. Interior aircon/heating fan selector faulty.
    By manvr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2006, 02:07 PM
  5. Lights In Heater & Aircon switch's not working
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2006, 08:30 PM
