Results 1 to 6 of 6
Thread: VX vibration and grinding noise... transmission prob?
    VN Calais V6 / VX S V6 Ecotec
    Mar 2010
    Default VX vibration and grinding noise... transmission prob?
    Hi Guys,
    I have a VX S pack V6 Ecotec with Auto transmission.
    The car has always made a slight vibrating sound when in gear (D) and stationary (standing still). The vibration seems like its coming from behind the dash. I'm pretty sure its the transmission thats causing the vibration tho - as when I select Neutral (N), the vibration and noise stops. Then if I put it back in gear (D) the noise and vibration comes back.
    Just recently (past week or so), the vibrating noise when stationary and in gear (D) has gotten worse.
    And now when I take off from a stand still, there is slight a grinding sound which seems to be coming from the gearbox or lower back part of the engine (just behind the dash). As I accelerate more out of first gear the grinding disappears. But then when the auto changes into second gear, the grinding sound returns and then disappears again as I accelerate more out of second gear as the revs go up.
    So the grinding only occurs at lower revs in first and second gear... possibly third gear too but not as much as compared to first or second.
    The grinding sound and vibration seems to be much worse too when the car is cold, and improves as the car gets warm. However the sound is still there slightly when warm.
    I have checked the transmission fluid and it is at the right level.
    Could this be a clutch pack issue?
    Or does it sound like the transmission needs a freshen up?
    Any suggestions are greatly appreciated.
    vx
    Aug 2009
    mate have you checked engine mounts and specially TRANYYS MOUNT??????????????
    vx
    Aug 2009
    my money is on the trannys mount its for 25$ from Holden and what an easy job man to replace. first jack up car and put on jack stands. second remove the 2 bolts underneath the mount third remove the supporting metal with 4 bolts forth remove 2 bolts from above the mount at that time u should be supporting the trannys with a peace of wood on jack just lift a little bit and hold it there remove the mount install the new one and all done reverse all steps..... that's it just in case u don't know....
    VX Acclaim Sedan
    Dec 2010
    Rye
    hey guys what the difference between a VX II and VX II S is there a big outstanding difference or not really?
    VX Acclaim Sedan
    Dec 2010
    Rye
    Mar 2010
    Thanks Ill check out the mounts and let ya's know how it goes
  1. Grinding noise
    By crackles23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2010, 01:08 AM
  2. grinding noise....:(
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 12:15 AM
  3. grinding noise
    By shooter in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2009, 06:26 PM
  4. grinding noise
    By reggie_c2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 08:40 PM
  5. Transmission Grinding Emergancy
    By dogermano in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2005, 07:11 PM
