Results 1 to 6 of 6
Thread: vy ss rear suspension and diff
    VT Acclaim Wagon
    Oct 2008
    Default vy ss rear suspension and diff
    Somebody on this forum said the sedan and wagon suspension are the same. They are not. My GMH service manual says the track width for the sedan is wider than the wagon and the bottom shock absorber mount is different. After all that, will the VY SS sedan rear suspension/cradle and diff fit in my VT wagon? enquiring because there is a VY SS sedan complete rear end, cradle, 3.08 lsd and brakes available to me for cheap and I would like to put it in. Camber wear gone plus better handling.
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    Dont quote me but id reckon the cradles would be the same , diff centre for sure , brakes most likely , difference would be in the trailing arms . Mix an match
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    VT Acclaim Wagon
    Oct 2008
    nathanVS "aren't wagons live axle...?" Not mine nor any other VT onward Commodore wagon. All IRS stock standard. The one I am looking at is also 3.08 LSD, just what the doctor ordered. I believe that the bolt up is the same, just the track and shockies different. only other thing is the exhaust mount. 5.7l V8 brackets. Modifications may be needed there. My VS Berlina wagon did have live axle with irs an option
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Hmm thanks for the correction, i thought they all were but wasn't sure about newer models.
    ve sv6
    Aug 2010
    wagon and ute have the same trailing arms, corect different shock mounts, x-members are the same.
  1. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  2. L67 into VS is the suspension,diff ect the same??
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2008, 07:18 AM
  3. Whats the diff re SS v HSV suspension?
    By Clinster in forum General
    Last Post: 24-12-2007, 09:10 AM
  4. Diff or Rear suspension grinding sound
    By owen_wongdoe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 11:01 AM
  5. Q: Diff and suspension replacement costs
    By Custom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 11:41 AM
