Results 1 to 4 of 4
Thread: change cam sensor
    03 5.7 vy ss
    Mar 2008
    ipswich qld
    Default change cam sensor
    hey guys, was told need to change the cam sensor, just wonderin can anyone tell me how to change it and where it is and looks like, any help on this would be muchly appreciatted, cheers
    oh it's a vt v6
    D22 St-r Navara
    Dec 2010
    perth
    its held on with one screw on the timing cover above the crank seal. then just use a flat head driver to pry it out lightly
    03 5.7 vy ss
    Mar 2008
    ipswich qld
    vr acclaim series 2
    Nov 2009
    hobart
    There is a magnet in the timing gear that you change as well but you need to pull off the timing cover for that. Dont wreck your sump gasket when you put the timing cover back on!
  1. how to change co2 sensor
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2010, 01:43 PM
  2. Alloytec Oxy sensor change - HELP!
    By Danoz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-11-2009, 07:50 PM
  3. [VR-VS] Change a Coolant temp sensor (V8)
    By undar8ed1 in forum Holden Commodore How-To's
    Last Post: 22-05-2009, 08:09 PM
  4. how 2 change crank angle sensor ?
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2008, 06:21 PM
  5. Remove Harmonic Balancer to change Crank Angle Sensor?
    By aklahr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 09:18 PM
