Results 1 to 5 of 5
Thread: Horn doesn't work.
    VX Executive Wagon
    May 2009
    Default Horn doesn't work.
    Hi,
    The horn has stopped working on my VX Commodore. Could it be a relay, fuse or something else? What should I try?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    First check the horn fuse (No25) under the steering column. If the fuse is ok check the connections at the horn (driver's side behind the bumper and you can access it from under the car) if ok check the horn itself by connecting 12 volts directly to the terminals on the horn). If it is still not working check the connection under the horn pad, this will be more difficult and should not really be attempted if you don't know what you are doing with the airbags. Try the first three suggestions first and see how you go.
    MY RIDE
    vr acclaim series 2
    Nov 2009
    hobart
    If none of that works try viagra!! Nah jokes. BUT!!! To add to that, if the horn works direct off the battery, THEN check in the steering wheel. If it doesn't work off the battery then get a new horn.
    VT Acclaim Wagon
    Oct 2008
    Just by the way, there is a horn relay, relay# 3 under the plastic panel on the driver side inner guard. most of those relays are 16 amps so just swap one out to see if that is the problem. $0 at your friendly wreckers. The horn on my VT sounds like it belongs on an xf cab. Upgrading to stato duals asap
    vy calais .vs commodore
    Sep 2005
    blacktown
    dont wory a bout the horn use the birdy
  1. help.. VC Commodore, Horn won't work
    By commodorian1 in forum Electrical Wiring / Questions
    Last Post: 25-06-2010, 09:48 PM
  2. horn doesn't work....why?
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-01-2010, 11:33 PM
  3. Non Airbag horn doesn't work?
    By Old Colts in Oz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2008, 09:13 PM
  4. Horn Doesn't Work
    By munchie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2007, 07:55 AM
  5. how to get my horn to work
    By canb_vn06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-07-2006, 12:01 AM
