Results 1 to 6 of 6
Thread: ac fan stuck on in vt calais
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Default ac fan stuck on in vt calais
    Hi
    my mates aircon fan in his vt wont switch off even if the car is off.
    I read on here that the relay for the fan could be the fault.
    I can only find the aircon relay. Is this the one or is it seperate.??
    I may have broken the law, but that doesn't make it wrong!
    keeny's Avatar
    keeny is offline keeny
    vz calais alloytec 190
    Dec 2008
    Maitland, NSW
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    cheers
    ill go check it out asap
    vx s pack II
    Jan 2010
    aLKIDA
    check under the bonnet there is a fuse panel. There are fuses and relays under there.
    There are 2 relays one for high fan speed and the other one is for low fan speed.
    Are both the fans on or only one?
    Dec 2009
    It's probably the fan speed controller, it's a transistor mounted on a heat sink and sits in the plenum chamber and to get it out you need to look behind the glove box. What usually happens is this component shorts out and the fan will run all the time even with the ignition off. You can test it by unplugging it and if you need a new one you can either go to Holden and pay heaps for a new one or take it apart and silder in a new transistor which costs less than $20.00 of you can find one. I fixed one a while back and think the part came from WES in Sydney.
    keeny's Avatar
    Dec 2008
    Maitland, NSW
    are you talking about thermo fans or air con blower. speed controler is internal on climate control. sounds like the relay. how did you go?
  1. !!!!stuck!!!!
    By jaron88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-06-2010, 12:33 PM
  2. LCD screen stuck on oddometer 3 window VZ Calais
    By hwystar in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2008, 10:14 PM
  3. help! vn calais power window stuck
    By my vn calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2007, 01:04 PM
  4. im stuck what to do next?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 10:45 AM
  5. CD Stuck
    By VZCalZone in forum Car Audio
    Last Post: 26-04-2006, 11:48 PM
