Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By accentstencil
Thread: fuel sender replacement!
    Sep 2007
    Default fuel sender replacement!
    hey all! so as a few of you may read, my fuel sender appears to be dodgy, giving me an inaccurate reading.. i've heard the tank needs to come out for this.. is it really a prick of a job?
    how much should i be looking at spending at fixing this? note, it's on factory gas aswell.. so does that mean that there would be 2 senders?
    how much would your average mechanic charge to do something like this?
    i'd rather do it myself if possible though!
    thanks, andy
    Dec 2009
    The fuel gauge and fuel pump are all in the one assembly and the tank has to be removed to get it out as it goes in the top of the tank.
    You'd haver to check if the sender is available as a seperate part otherwise you'd have to buy the whole unit.
    It wouldn't take that long to get the tank out, you would be best doing it with the tank as empty as possible and the only real issue I could see is getting the fuel hoses off as they can be tricky and get broken if you are not sure what your doing and for example try to use a screw driver on them.
    VT Acclaim Wagon
    Oct 2008
    Sender, pump and in tank filter are available as separate units. quick connect fuel line fittings are used for all fuel line connections. Push, squeeze, pull. If you hold your mouth right! By the way, if you manage to damage the tank, it is not serviceable, replacement tank needed. Advice from Holden is that you should use a brush and compressed air to remove any accumulated rubbish from the area around any fuel connection so as not to contaminate your fuel lines. Really bad for injectors.
    Sep 2007
    sounds alot easier with a hoist... possibly it should be a mechanic jibby..
    any ideas on cost?
    thanks mate, andy
    ls1 stato
    Sep 2010
    weribee
    Sep 2007
    thanks for the heads up guys!
    i'm assuming the lpg has a different sender then the ulp?
    i *think* both are faulty, although after thought, it leads me more to thinking the gauge is at fault!
    thanks
    VT Acclaim Wagon
    Oct 2008
    After having read some of the relevant posts on "Just.commodores", I am convinced that inaccurate fuel guages are standard equipment on the VTs. Even the VZs have the problem. My daughter has a VZ which, on a trip back from Queensland, told her she had less than 50ks to go. On filling up at the next servo, the thing took 42 litres to fill! There was still 33 litres in the tank! More like 400ks to go.
    Sep 2007
    Yeah, I've read that too!
    Although.. do we know the cause of this problem?
    It's irritating the shit out of me!! I want it fixed!!
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    VT owner here , my gauge lies all the time , hardly ever under half a tank in her anyway so dont worry me
    At 43 a wealth of info , but still heaps to learn
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Yes, it is very annoying. I've run out of fuel a few times now when I allegedly had 140 kms or more to go
    MY RIDE
    VT Acclaim Wagon
    Oct 2008
    there is a post on here that goes in to recalibrating your fuel sender/fuel guage. Want to give it a go? Manual fuel calibration for vt vx finally revealed for cars with 1 window dash Might help. Let us know if it does.
    Sep 2007
    thanks graham! tried it..
    doesn't work!
    after playing with the settings, it rendered my car unstartable! so earth off the battery for 20mins to reset everything..
    gauge is still out!
    i've got a cluster on the way! i'm assuming it will be fixed when drbob calibrates it for me!
    if not, tank out, new sender!
    couldnt be bothered!!
    thanks
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Quote Originally Posted by accentstencil View Post
    funny you say that my mates VY runs out with 120km till empty on the dash
    Sep 2007
    are your needles accurate though? or is it just the till empty display that's out?
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah still shows above empty probably gauge calibration error i think there was an update for the dash at one stage
  16. #16
    VT Acclaim Wagon
    Oct 2008
    Andy, my bad but talk to the guy who put the original post up, he might be able to help you. Failing that, talk to a Holden man with a tech2 in his hand and he will tell you exactly what is wrong.
  17. #17
    Sep 2007
    Yeah, I'm arranging a time with drbob! I'll get him to calibrate it all correctly! Thanks for the heads up..
    I can hold off for a bit, just you know how it is!!
    Thanks
  18. #18
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    Forget it its like tryin to get a headjob out of a hooker for free!!!!!!! live with it
  19. #19
    Sep 2007
    Haha! I don't let things get the better of me though! If I want a free headjob off a hooker, i'll get one!!
    All in time
  20. #20
    Boltonator_VT is offline Recreational User :)
    VT V6 Acclaim Auto
    Jun 2009
    Kumeu, Auckland
    Me and my dad got the thing out, the fuel sender does come as a separate unit and if I remember rightly, the fuel pipes are long enough to just take the assembly off of the fuel tank and replace the sender unit without disconnecting any fuel lines. The fuel gauge worked fine after that.
    I never understood the sales of the Kia on the Holden lots here in NZ. I couldnt think of any cars that could be so different.
  21. #21
    VY 5.7L Calais II
    Jan 2011
    Broken Hill, NSW
    Quote Originally Posted by Boltonator_VT View Post
    Hey Boltonator. Where did u get the sender from? holden told my dad that they don't separate it.
  1. fuel sender
    By MRVX6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2011, 05:02 PM
  2. vs fuel tank sender unit to vk fuel gauge
    By joe65 in forum Electrical Wiring / Questions
    Last Post: 11-09-2010, 02:08 PM
  3. Fuel sender
    By VR_meanz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2010, 08:20 PM
  4. Fuel gauge or Fuel sender?
    By Defected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 03:19 PM
  5. VX LPG Fuel Sender
    By deserthead in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2009, 09:59 PM
