hi guys, just noticed my drivers side manifold is leaking and then saw it has this bulge in it, the bolt towards the rear also has this same bulge and is actually leaking worse, im wondering has someone done them up too tight or is the bulge normal, here is a picture
Looks like your Rocker Cover on Drivers Side. It's made of hardened plastic. Pick up a replacement at wreckers or holden. Remember to replace gasket seal around rocker covers as they have a life span and leak after a long while. Easy enough fix, just undo all the bolts and carefully lift up. Put new rocker cover on with new seal and tighten back up.
bah i wrote this after i had already started our xmas break up celebration (drinking) yeah i know its a rocket cover haha silly me
after looking at this HOLDEN VN VP VR VS VT V6 COMMODORE ROCKER COVERS (eBay item 150534033910 end time 24-Dec-10 18:38:41 AEDST) : Cars, Bikes, Boats im wondering is the bulge normal if anyone else could comment aswell it would really clear things up for me
Nar the bulge is normal man just change rocker cover gaskets. U can't overtighten em coz the bolts bottom out so really can't go any tighter unless u wanna break em lol
Gen3 6spd Manual VT SS
VT V6 Manual turbo![]()
u can tighten em more just put and extra washer on each bolt
alright thanks guys, its just that its been leaking so bought new gaskets was about to do the job and thought oh shit, the gaskets are going to be no good to me if its actually leaking out that bulge, but if its normal thank you all much appreciated
The bulge is part of the design of the rocker covers. Leaking rocker covers on ecotecs is a common common fault. Change em and clean the rocker cover to head mating surface with thinners to remove all deposits of oil and you will be fine. Tighten the bolts firmly and no more as they are only a 12 Nm bolt which is not a hell of alot
VYII Calais L67
