hey guys! so I've been researching about installation of power windows in my vt.. apparently some series one's have the wiring looms setup, just ready to plug and play! after ripping the door skin off my drivers side door today, i was pleased to find a vacant plug! I'm just hoping this is the loom required?
2 wires, into one plug! Dark green and a lighter green?
Thanks!
Andy
Those colors sound like its the speaker wires? Do you have the speakers connected? Aftermarket stereo/speakers maybe?
Yeah, I thought that myself a few hours after posting this! Especially considering I installed the stereo including speakers myself!! Bad. Ha ha.
That's quite depressing!! Looks like an entire loom install then if I wanted to fit them?
Thanks
Without meaning to derail your thread (but not wanting to post ANOTHER Powerwindow thread), what makes the windows go up/down fast and smoothly?
I have one rear window that doesn't work.
but the front's can sometimes take what feels like a bit of a wait, to put them up, especially if doing both at once.
Just wondering if there's a way to combat that ?
Rear window I think is the motor itself, doesn't work from front or rear window switches.
I've left it for now, it doesn't bother me.. I'm usually driving :P Plus I rarely put rear windows down.
Will check out whether it does it engine running or not though, thanks.
To eliminate the motor as the problem you can connect 12 volts directly to the terminals of the motor. It doesn't really matter which way you have positive and negative as one way the window should go up and the other way the window should go down. A broken wire in the door loom happens a lot.
MY RIDE
You should only need the door looms. They unplug from the main harness just inside the pillars. VT Series 1 are one style of door looms, and VT2, VX1 and VX are another. If you're going to use the newer looms on a series 1 you'll need to know how to use a soldering iron. I successfully put Power Windows from a VT2 into a VT1 the other week and all works perfect.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
