Results 1 to 21 of 21
Thread: Problems lol
    VT calais 1999
    Jun 2009
    Gympie
    Default Problems lol
    ok guys cars been running great till i left the cap of the radiator and boiled her dry fell like a dick lol but anyway car red lined on heat meter then shut its self off.
    systympos now are
    loss of heater in car
    very rough idle
    radator not holding water (but no leaks are found)
    now i guess i have cooked the oil so i am going to change that anyother suggestions or question???
    vx custom 600RR
    Oct 2010
    VT Acclaim Wagon
    Oct 2008
    how long after it boiled dry did you put water back in? Too soon, oska is on the right track. The miss makes me think head gasket. Also there may be a cracked head or block. Any water/coolant/steam coming out of your exhaust. Any water in oil (milk coffee) or oil in radiator. More than normal condensation under the oil filler cap? all things to look at. Should have mentioned this earlier but a compression test will find a blown head gasket fairly quickly.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is online now Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Fill the radiator with water, leave the cap off, start the engine and give it a bit of a rev. If it blows water out the radiator, she's stuffed.
    If an engine has been cooked that badly to burn the oil, replace it with another engine.
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Warped head/blown head gasket.
    Bye-Bye Ecotec.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Jun 2005
    Because the temp gauge goes up when the water gets hot, but then it goes back down when there is no water to read anymore
    Just replaced an Ecotec this week, exactly the same problem.
    calais24/7's Avatar
    Jul 2009
    true But you can actually smell it when it's red hot and cooking itself..... not that i'd know
    2002 VXII S
    Sep 2009
    Quote Originally Posted by SabbathSS View Post
    Bye-Bye Ecotec.
    Just a question, would that completely root the engine? Just trying to understand how it would?
    Jun 2005
    Quote Originally Posted by abclarke View Post
    A number of things really....
    1) Piston rings loose there tension from being so hot
    2) Pistons can grab on the bores when overheated, causing damage to the pistons and/or bores
    3) Oil gets overheated/burnt and can destroy bearings
    4) Head and/or block can warp (block is an extreme case, but does happen)
    5) Cracked heads and/or block.
    Just to name a few really. But yes, generally it results in a stuffed engine.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    It's a well known and documented fact that internal combustion engines allowed to overheat will 'die' sooner or later. Suggest a rebuild or replacement engine.
    VT calais 1999
    Jun 2009
    Gympie
    so in your own opion whould u replace the engine or get a rebuild done and if i replace where should i find a dencent engine
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    sounds like its time for an ls1.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by DLFHUB666 View Post
    Yer but maybe a iron headed engine would recover from more of his mistakes.
  15. #15
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    well.....
    personally i would refill cooling sytem and run car and keep topping it up as it idles
    when it wont take anymore turn car off and top up
    open bleed screw on top engine side of top radiator hose and top up until comes out here
    tighten screw
    then put cap back on
    over fill the resevoir
    start car
    with it IDLING ROUGH give quick rev and see if it MISFIRES
    if it does (shudder blah blah blah)
    unplug injectors one by one and see if it has the same amount of misfire or makes it worse
    if one injector makes it worse likely that cylinder has an issue with the combustion of fuel
    the next step would be to pull all the plugs out and compare COMPRESSION PRESSURE
    if one or two cylinders are lower than the others that BANK/SIDE head is the one requiring new gasket/head
    obviously if your thinking of repairing the motor you need to watch the temp gauge as you refill the system to make sure it doesnt over heat again...
    if it goes to the red at idle then turn it off and fill with the bleed screw open then try again from the start
    repeat ^ that bit 2 or 3 times until stops instantly overheating (an air pocket at sensor normally) if still instant overheats likely new engine as heat getting into coolant at no 2 cylinder gasket
    to coolant jacket at sensor feed in head (my guess)
    hope this helps....
    note if engine oil is milky likely head gaskets skip to a compression check
    if no misfire after refilling cooling system likely temp sensor reading was affecting fuel mixture BUT would need to drive and see if over heats and then starts misfiring liekly head warped
  16. #16
    VT
    Sep 2009
    funny....exact same problem inlaws had with VS comodore....loose Radiator cap..overheated but maybe not as bad....told me to look at it....
    After a trip to mechanic..the report was....water pressure test ok...compression down ( abit) on 1 cylinder... new plugs and leads...
    ( engine has over 200000Ks, may have been worn earlier.?)
    After they drove it home from mechanic...I noticed the oil and filter was still old..? So I changed both with new..
    It idled a bit rough, but Ive seen worse...It drove wonderfully, smooth and powerful.. 20Kmh-120Kmh no problems at all..
    Only when you stopped at lights etc..it idled rough until you drove off again...!
    I checked -Water temp excellent no loss...oil good no smoke...no error codes...coil packs/dfi all good...(tested)
    I noticed 1 injector doesnt seem to respond to cylinder3 when disconnected..? the other 5 do....
    I'm hoping for a blocked injector.......Im driving it for a week with injector cleaner in the tank and ultra98 fuel..to see if it clears, if not
    I will try new injectors...
    Do you think I will have any luck...or Am I on the wrong track guys....??? thnx for any help..
    I disconnected the injector #3 and drove car to check....ran like shit..lol so the injector must be ok...but still doesnt respond during idle......maybe thats the way it is..?
    Keeping eye on water bubbles in radiator...a couple bubbles every now and then.....( although mechanics pressure tested it and checked OK )...maybe a slight faulty head gasket..??..drove car 100Km today...water temp ok, no overflow leaks...still driving and testing....BFN.
  17. #17
    VT
    Sep 2009
    LATER.......
    Got the heads off....2 dead cylinders,..4 & 3 suspect faulty valves..leaking air under pressure from compressed air test..
  18. #18
    Jonesy484's Avatar
    Jonesy484 is offline Quicksilver Club :)
    VX I S
    Sep 2009
    Melbourne. Victoria
    Put it on a tray truck and take it to a mechanic, one of my mates tried to fix a similar problem, ####ed his eotec, now runing an alloytec
    Quote Originally Posted by DM 55 WA View Post
    venetians make me want to punch kittens
    Special thanks to B-Roca for my new sig
  19. #19
    VT
    Sep 2009
    We'll see.......lol
    dismantled and checked heads, alls looking ok so far...valve regrind,no cracks, no warp.. waiting on gasket set..
    will reassemble this week hopefully ...and test, if anything it wont be worse...i hope for an improvement at loaded Idle..and no leaks...cheers all..
    I'll post my results soon....
  20. #20
    VT
    Sep 2009
    Quote Originally Posted by denholden View Post
    We'll see.......lol
    Car all assembled this weekend, Problem fixed...runs well now, no rough idle in drive.
    Obviously diagnosis was correct..faulty valves.. had the heads valves re-seated/shimmed/guides..
    total cost...( heads reco'd, new injectors, gaskets, a few special tools, sealants,oil, some new bolts.. roughly $900 ) Labor was mine..lol
  21. #21
    VT S2 Calais 5.7 A4
    Aug 2005
    That was a cheap(lucky) fix. Well worth the effort.
LinkBacks (?)
  1. 24-05-2012, 09:33 PM
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. Gas Problems
    By Vazard in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2006, 02:25 PM
