Hi Guys,
I installed a new radiator a while back, which had different fittings for the Auto transmission cooling lines (this one had 2 connections, in lieu of 4 that the original had). So with a bit of pipe bending, making it fit, etc... I got it all hooked up no worries. But now I am looking at replacing the cooling lines that run from the Auto to the radiator and back and adding a separate transmission fluid cooler, I am just wondering what size the hose fittings are that connect to both the radiator, and the transmission are?
Any help would be appreciated.
Cheers.
151 Countries, One Cúl-Báire!
Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
Cúl's AUII XR8 Ute!!!... Clicky Clicky!
inverted flare (3/8" pipe) 5/8" on trans (4L60, 4L65), 5/8" or M16F depending on rad.
