Results 1 to 6 of 6
Thread: Vt Calais heater not working??
    bbb
    bbb is offline
    2010 Sv6 Wagon
    May 2009
    Default Vt Calais heater not working??
    Hey guys...can anyone make a suggestion..
    I have just replaced the heater tap, all pipes connected system bled...etc etc now there is no heat coming out the vents???
    The car get's up to temp all ok (and temp guage read's between quater and half) and the a/c work's fine but when i set the climate control to 30 or H or any temp for that fact it stills blows cold air??
    Before any one ask yes it has a thermostat in and has just been replaced.
    Things been changed recently..
    *Radiator
    *all pipes
    *thermostat
    and now now heater tap.
    The motor did get bloody hot when the heater tap shit itself on the freeway but seems to run fine...no water in the oil or vice versa. I have searched pics and all the pipes are connected up right for the heater tap.
    On a side note they fan speed amplifier was changed about 12months ago so no problems with the fan speed control's etc..
    Any suggestions be great....
    BBB
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Did you re-connect the vacuum hose to the heater tap?
    MY RIDE
    bbb
    bbb is offline
    2010 Sv6 Wagon
    May 2009
    vx s pack II
    Jan 2010
    aLKIDA
    Check the vacuum line back of the inlet manifold and the heater tap make sure there no holes and that it is connected. Check the one way check valve.
    might be playing up.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    see if u can get ur hands on a thermo gun and check the inlet and outlet pipes on the firewall 4 the heater core (best 2 do it inside the cabin tho). if 1 is colder than the other u prolly got a blocked heater core.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    With the engine running and at operating temperature,
    Turn the climate control OFF,
    then turn it back On.
    Now adjust the temperature and see if its working.
    I like my roo well done
  1. Heater fan not working
    By RyanNZ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2010, 11:27 PM
  2. VZ heater not working
    By Summer-Sickness in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-06-2010, 12:44 AM
  3. Heater fan is not working
    By vb_commie in forum VB - VC - VH - VK
    Last Post: 07-07-2008, 11:47 AM
  4. heater not working in vp calais
    By tysons_2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 05:45 PM
  5. How to get heater working
    By hittmann81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-04-2007, 12:37 PM
