whats the normal ride height for a vx berlina s1, with a bit of a load she bottoms out, not sure if the springs sag after a while or its had after market lowered springs put in it
can you replace the rear boot garnish, just the lights section if so how do you take it off without wrecking the seal, at the moment it leaks into the lights and pours out when the boot is opened
where can the water come into the lights it all looks sealed
thanks
