Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Irukanji
Thread: Debadging a VT
    1987 VL commodore
    Jan 2010
    Default Debadging a VT
    Hey guys.
    I was wondering if anybody could tell me what I need to know about Debadging my VT?
    I imagine it would leave some kind of glue and/or rust marks underneath... But that's just a guess, I honestly have no idea.
    also...
    I'll most likely leave it clean, but if I WAS to decide to put Chev badges on it, probably won't, but just in case, how would I go about doing that?
    Thanks guys.
    keeny's Avatar
    keeny is offline keeny
    vz calais alloytec 190
    Dec 2008
    Maitland, NSW
    all badging should come off pretty easy and if you be carefull u shouldnt scratch the paint. then u can pick off the left over adhesive/double sided tape with your fingernail and use wax and greese remover or prepsol to remove any residue. the bonnet emblem and boot emblem do have locating pins and will leave 2 holes in each if you remove the badges so u could either leave them, replace them with chev badges, or weld/ putty up the holes, prep and respray (much more work). good luck.
    1987 VL commodore
    Jan 2010
    Wow, i'm glad I asked before I tried it, didn't even think about locating pins. Looks like Chev badges are the go then. Would they come with the same locating pins, or would I have to GLue them?
    VT
    May 2010
    Wollongong
    even though they have locating pins they are still glued on
    I took off my executive badge today off my VT wagon and plan to take the commodore one off another day and move it up higher
    take alook at this thread is heaps good
    Debadge your car in 10 minutes, WARNING dial up users
    to get rid of the remaining glue i just used a tiny bit of metho let it sock in then started rubbing away at it it come off in like a minute then just gave the area a nice polish and come out good
    308 vc
    Dec 2010
    North east Adelaide
    please no chevs!also with the other side badges a hair drier or weak heat gun will soften the glue and reduce risk of damaging paint.
    vt s1 clubsport 5lt 5spd
    Dec 2010
    dandenong
    i debadged mine before i got it painted. its a good look. i reckon it makes new paint look better if its done well
    VT
    May 2010
    Wollongong
    also thought i would ask instead of making a new thread does anyone know of a good adhesive to re glue them back on
    keeny's Avatar
    Dec 2008
    Maitland, NSW
    you mighy be able to get some good 3M double sided tape. i dont like the badges and on my vt i only had the boot emblem and the front emblem on my monaro front bar , made it look really clean.
    VX equipt
    Jun 2011
    hey mate
    i looked at another persons post and removed my badges the way they said, but for some reason it removed the gloss that was under the 'commodore' badge and the 'equipt' badge. so basically there is 2 rectangles left where the 2 badges used to be.. what do i do? i tried a cut n polish but it didnt do anything
    97VT SS super6,daily 05 holden barina(opel)!!
    May 2009
    I degadged my vt with a hair dryer and then used abit of metho quick wipe/then clean afew times till all off and viola...just make sure that you wash it straight after aswell to make sure no metho is left on the area....the 2 holes you can get welded and just a respray your prob looking at about $300 each boot/bonnet
    Also check my ride,sitting on HSV R8 19's
    " And on the Seventh day ,GOD created Commodores!!!! "
    snuff33's Avatar
    snuff33 is offline Get a manual up ya
    VT Commodore S
    Nov 2010
    Southport
    i just replaced the holden badges with HSV chrome ones for my VT. they look better than chev badges and saved me from welding up the holes and respraying my panels again
    if you cant find it, grind it
    VX
    Mar 2011
    SA
    I debadged mine a few months ago, got a spotless result with some Tooth Floss, Bug and Tar remover and a hair dryer.
    Cant stress how important heating it up is. A mate heated some of his badges and didnt heat some others and you can tell the difference.
    VTII Gen3
    Dec 2010
    I debadged mine by just getting a fingernail under the corner of the badge and pushing side to side... most of them are just glue. You can also use a length of fishing line behind the badge to cut through the glue. Only takes a few minutes to do the whole car!
    PS It just so happens I sell Chev badges... both with pins and without. PM if you'd like to see photos
    Vt calais series II supercharged v6
    Dec 2011
    Hey can anyone fill me in post's like this helped me get info so I'll take my boot and hood badge's off than paint them black than put them back on anyone know if I need to add more glue and what type
  15. #15
    1998 VT Commodore
    Jan 2012
    Heathcote
    Why anybody would put a Chev badge on a Commodore, I'll never know.
    EDIT: Just debadged the VT, took the "commodore", "executive" and the 2 "ecotec v6" badges off. Makes the back look much better, not much of a change to the sides though, might need the clear indicators to be noticeable.
  1. Debadging
    By VSH00n in forum General
    Last Post: 19-10-2010, 02:26 PM
  2. Debadging
    By Bobski in forum General
    Last Post: 07-12-2009, 04:58 PM
  3. debadging the vp
    By scouser king in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2009, 11:29 PM
  4. Debadging help
    By Brin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2009, 12:46 PM
  5. Debadging
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2007, 06:11 PM
