Results 1 to 7 of 7
Thread: 1999 VT Wagon Handbrake
    2003 VY SS Ute M6 2005 WRX STI
    Nov 2010
    Default 1999 VT Wagon Handbrake
    Hi Folks just wondering if the VT handbrake is adjusted by using the locator under the plug on the rears? Recently I adjusted it right up on the lever and its done nothing so im hoping if I do the adjustment on the rears they will come back to life again? Cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Adjusting at the handbrake shoes is the correct method.
    MY RIDE
    Nov 2010
    for some reason the small wheel located inside the rear wheel assembly will not move up or down with a screw driver is this is what is required to do or am I doing something wrong? cheers
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by vsute97 View Post
    Make sure your handbrake is off, you're rear wheels are off the ground and the front wheels are chocked. I adjusted my VY recently and found that these adjuster wheels can be a little hard to turn at first, one side was slightly harder than the other anyway.
    vt executive
    Dec 2010
    penrith
    i did mine today with a screwdriver via the rear wheels
    was bi*ch to do but hand brake is
    heaps better now well worth doing
    "I didn't cum on you pete......I swear !"
    VXII
    Nov 2009
    The thread of the adjuster isn't greased at the factory, or if it is, they don't put much on.
    If yours is stuck you need to take the handbrake shoe off, take the adjuster out and grease the thread.
    vs commodore
    Oct 2009
    Tamworth NSW
    I find its easier to first up remove the rear caliper,only 2 bolts hold it on, and then remove the disc,which just slides off once the caliper is removed,so you can then access the handbrake components,and then free up and lubricate the adjusting wheel with a smear of high melting point grease on the adjusting wheel threads before re fitting the disc and then adjusting it.Ive had this problem with nearly every commodore I have adjusted the handbrake on.
  1. VY Wagon Handbrake Problems
    By pwarren3030 in forum General
    Last Post: 04-11-2010, 10:32 PM
  2. VP Wagon Handbrake Problems.
    Last Post: 04-11-2010, 10:23 PM
  3. VR Station Wagon Handbrake shoe replacement
    By Flippity in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2010, 08:06 PM
  4. vs wagon door locks & handbrake faults
    By vss2wagon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2008, 12:55 AM
  5. vn wagon handbrake
    By radiohead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 04:21 PM
