Results 1 to 5 of 5
Thread: Need vt help asap
    Dánsvt10304's Avatar
    Dánsvt10304 is offline Nate10304
    98 VT berlina
    Oct 2010
    Armidale
    Exclamation Need vt help asap
    last night after comming home i pressed the lock button and the car beeped at me only once so i went back to the car pressed unlock got in started it up all normal shrugged it off turned it all off locked did the same thing
    went out just then the unlock button didnt work so i was like ok flat battery so i got my spare same thing so i stuck the key in the door and it unlocked only the drivers side jumped it went to start it nothing looked around noticed the alarms light wasnt flashing and the dash was 100% blank
    so im leaning towards a flat battery
    anyone else got any other ideas first?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Make sure the battery terminals and clamps are clean and tight.
    MY RIDE
    VT Acclaim Wagon
    Oct 2008
    All the usual suspects, battery, alternator, cable connection points and a possible earth leak/short somewhere. Just a matter of elimination. When did you last check battery water, terminals and the cable mounting points, both ends of all cables, for corrosion. Check all your fuses inside and under the bonnet while you are at it. Only takes 1/2 hour and well worth doing. Can save you a bundle at the sparkies
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Sounds slightly like mine. i have one terminal that plays up from time to time. i have heard the one beep. ive had the cd player ask for the code the next day. ive seen the dash go blank. and its all this terminal that plays up occasionally. i'm just going to change them both when i get around to it.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    98 VT berlina
    Oct 2010
    Armidale
    got the battery checker out battery dropped its guts completely no idea how no lights or anything where left on meh
    problem fixed anyways thanks all
  1. VR 93 needs help!!! ASAP
    By maco_butterfly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2008, 02:42 PM
  2. need help ASAP PLEASE!!!!!!!!!!!!!
    By lgnd3800 in forum General
    Last Post: 11-09-2007, 08:50 PM
  3. need help asap
    By mickooo in forum Electrical Wiring / Questions
    Last Post: 16-01-2007, 07:33 PM
  4. Need help ASAP pls.....
    By freakme in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2006, 03:45 PM
  5. need help asap
    By bradvt98 in forum Car Audio
    Last Post: 16-12-2006, 06:03 PM
