Results 1 to 7 of 7
Thread: Supercharged vt problems
    VL Calais Turbo, DVS.42L Vr
    Aug 2008
    Nowra
    Default Supercharged vt problems
    Hey i have a vt commodore which is supercharged. It was originally standard but previous owner bought supercharged engine and charger and converted it. Keep having problems with gearbox changing gears weird and when putting from park to gear sometimes it will jump hard into gear. It also has lights coming up on dash but when i took it to a transmission bloke he said there was nothing wrong with gearbox. he put diagnostic on it and read all the codes which were mostly sensor problems. all sensors have been replaced and no change. Im not sure if the ecu has been changed anyone know what could be dooing this
    VS l67 statesman
    Dec 2008
    Ok I assume its had an l67 conversion ? the gearbox problem sounds like the Throttle position sensor is playing up did you replace this and then reset the computer? and also A larger TB will throw out the TPS and you will need to get your tune adjusted to suit
    join this if you havent already
    www.l67torque.com • Information
    Aug 2008
    Nowra
    Thanks mate i will have a look at the throttle position sensor but i am sure its also new
    Aug 2008
    Nowra
    tps sensor was replaced and still the same. Car will be fine to drive sometimes but as soon as the diagnostic light on dash comes on it starts buggering up
    VT SII 5.7 LS1
    Jan 2008
    Albany, WA
    What are the actual codes that are coming up?
    This you can check yourself by shorting out pins 5 and 6 on the diagnostic plug under the steering wheel.
    Aug 2008
    Nowra
    VT SII 5.7 LS1
    Jan 2008
    Albany, WA
    Quote Originally Posted by weastyvsaero View Post
    codes are 0019, 0013, 0022, 0047, 0049, 0063. These are the codes
    I've never seen those codes before. Does anyone know if the L67 codes are the same as checking them on a traditional 3.8? Or they use the different computer?
  1. VT Supercharged overheating problems
    By VTSL67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2010, 04:20 AM
  2. differences between vs supercharged and non supercharged engine harnesses
    By jwk87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2010, 07:39 PM
  3. Any problems with V6 supercharged engine?
    By huey67 in forum V6 Development And Modification
    Last Post: 05-12-2009, 10:29 AM
  4. problems with my supercharged 6 - again
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 11:56 AM
  5. Supercharged VT idle problems
    By 89-Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2006, 11:16 AM
