found this in the skicky at the top of the vt/vx section:Instrument warning lamps (ABS) - The ABS module consists of 2 main parts. A hydraulic unit and an electrical unit. The most common failure seen with the module is when the ABS Electronic module fails. This often results in a myriad of dash lights being illuminated, not just the ABS light. When the ABS Electronic module fails, it can also interrupt scanning procedures for the ABS, BCM (Body Control Module) and PCM (Powertrain Control Module).
Another cause can be water entry into the engine harness connection area, under the bonnet, against the right strut tower. Apparently, water gets onto and through the "horse-shoe" shaped plastic wiring support, which eventually tracks down to the ABS connector, causing all sorts of warning lamp issues. Foam fillers and sealants are used to help reduce the amount of water that can get through to these areas.
Hope it helps
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
