Hi everyone.
I've searched the forums and the internet, but mostly it comes back to the car running rough, which mine isn't, just plain rich.
I understand this is a extremely broad topic and I've done some homework into this and am hoping some others might be able to help me out here. Long story short, the LS1 is running far too rich. The car is off the road for 3 months, so now I can begin the process of elimination and fixing up loose ends with it.
The question is, what can cause the car to run rich? The fuel economy in the car isn't good, due to a s**t K&N air intake, and because it's been neglected to some degree.
So far I have changed:
- Spark plugs
- Ignotion leads
- Oxygen sensors
I know it isn't much so far, but I'm looking to get all bases covered. Can things such as the items listed below, adversely effect the fuel/air ratio?:
- ECU Coolant Temperatue
- Air Flow meter
- Throttle body
- Idle Air Controller
- Injectors
I'm not too sure where to honestly start, but I like to do my homework before I go to a mechanic for example, so I don't look dumbfounded.
Sorry for the rambling, I'm just looking for some direction to an awfully large question.
Many thanks, Tom.
Hey Tom,
Sorry to ask a question with a question... but... How do you know it's running rich?
^^^thats what i was gonna ask.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
I was going to suggest oxygen sensors but I see you have changed them. Did you replace them with a good well known brand or cheapies.
MY RIDE
Hi there Darcon.
Well, I can't be certain that it's running rich, but from what the old man and a few others have told me, the exhaust fumes smell pretty bad, like the fuel isn't being completely combusted (If that's the right wording)
I could be way off the mark, but the fuel usage is pretty high, and I don't know if you have to have the "nose" to know it's running rich.
It's what people have told me who are in the automotive industry have said. So I am going off what they have said, to some degree.
You can tell if it's running rich by looking a the spark plugs or the exhaust pipe. If it's black then it is running rich.
MY RIDE
High fuel consumption can be attributed to a number of thiings.
Provided there has not been any "TUNE" done to the ECU it will react according to it's inputs from a number of sources.
- Spark Plugs(You have changed these, so good)
- Leads(Done...)
- Coilpacks
- Blocked Air Filter
- Dirty or blocked MAF
- O2 Sensors(Done...)
- PCV / Vacum leak
- Fuel Leak
- Fuel Filter blooked
- TPS off
- Injectors, as you have said.
- Increased oil use???
...And the list could go on and on and on.
Suggest you take the car to a reputable LS1/Holden mechanic you trust in your area that can hook up the beast to a tech2 and check for any codes being thrown up.
beat me again.
I'm getting that just with an exhaust, no manifolds or engine work done.
As for exhaust tips, mine are pretty black, weren't black when I got the car 6 months ago, but pretty darn black now.
On a side note, how do you reset the ECU? Some say hold it at 2500 rpm for 10 seconds, some say just leave the battery disconnected for a duration of time.
Another thing.
Say for example I put the car into reverse, the revs surge. It gets the feeling like it's going to stall, but then the revs shoot back up.
It also does it in first before snapping into second. It doesn't usually stop till I give it some decent acceleration.
Fuel delivery problem maybe?
Also, do the throttle body and MAP look okay?:
Sounds like you could have a pcv/vacum leak somewhere or the IAT/MAF could be at fault.
TB looks ok, a little oily so got and buy a NON-Vented catch can and put it between the pcv hose and the TB.
MAP/MAF looks ok even though it's a little dirty(There are special cleaners to use on them as they are sensitive, so don't touch/scrub them...) Also I would go and get an LS2 MAP/MAF. Cheap as chips and no restriction(The mesh) and larger(95mm) compared to 80/85mm.
if it is the pcv hose your car will idle like shit , i just replaced mine an put in a catch can aswell just for looks really.
Thought I might update everyone here and let everyone know that the problem has been found. Turns out it was the coil packs. Apparently there is a misfire through the rev range and really bad on low to medium revs. Shame I couldn't pick it :/
Thanks to everyone who has contributed their time to helping me solve the problem. Rep will be given accordingly![]()
