Results 1 to 15 of 15
Thread: vx super 6 pulley
    vx super 6
    Dec 2010
    sa
    Default vx super 6 pulley
    hi just bought a supercharged vx it has a aftermarket pulley on the snout going by a boost gauge it had 8.5 psi i want to change it to a 10 or 10.5psi one but am not sure on what brand of pulley it is i have....i have posted some pics to see if anyone can identify it for me plz thanks in advance
    Attached Thumbnails Attached Thumbnails vx super 6 pulley-01012011055.jpg   vx super 6 pulley-01012011056.jpg
    vx super 6
    Dec 2010
    sa
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    if ya did measure it you would know/find out what boost its ment to have.. if its already the 10psi size ya shouldnt go any smaller/higher boost cause ya will loose power,(but if its got different rockers it will drop a bit of boost.. or guage could just be reading wrong, or have other issues causing ya to loose boost) .
    but i know its not the same as mine, mine has 5 bolts not 6 and mine is a zzp pulley..
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    Sep 2009
    goldcoast
    VS l67 statesman
    Dec 2008
    vx super 6
    Dec 2010
    sa
    vx calais superc6
    Sep 2008
    vx super 6
    Dec 2010
    sa
    vx super 6
    Dec 2010
    sa
    i have measured the pulley it is 86mm would any one be able to tell me what psi this pulley is please
    Sep 2009
    goldcoast
    it would be 10psi pulley i think... 8.5psi Seems pretty close to normal to see on the guage straight up... Mine was about the same but hit or got close to 10psi towards red line...
    Ya shouldn't go any smaller than what ya got now with out a cooler,
    vx super 6
    Dec 2010
    sa
    ok ty for your help .... hmmm if i have a 10 psi pulley i should get 10 psi at or around redline shouldn't i?...... it is stock except for the pulley and a 2 1/2" twin catback ex would the ex be affecting the boost ? i have been searching the forums looking for the how to to fix it found it a week ago but cant find it now i know you plug a hose off and put a filter on the actuator but cant remembe which hoses any help would be appreciated
    VS l67 statesman
    Dec 2008
    I pretty sure this is what looking for nut you will have to join www.L67torque.com to see it
    www.l67torque.com • Login
    My advice is dont though unless you want problems
    vx super 6
    Dec 2010
    sa
    thanks heaps for your help vsl67 ........i could i do this to eliminate where my boost is disappearing to couldn't i ? if it makes no difference then thats not it lol......... im pretty sure the boost guage i was using was accurate as its part of the dyno my car was on
    Sep 2009
    goldcoast
    vsl67 what probs have you herd of from deleting the bypass solenoid??? i thought deleting it just stopped the ecu from having anything to do with controlling the boost, and if its a little faulty and causing ya to loose a little boost ,will fix that too........ hmmmmmmm thou i have had to replace one accurator so far since deleting it
  15. #15
    Sep 2009
    goldcoast
    Quote Originally Posted by super06 View Post
    i'd expect/think it would get near 10psi if mine did, not 100% sure....just check all ya vac lines, check ya accurator's working properly, shutting fully and the diaphram's inside its not leaking, check ya belts clean and tight and not slipping..
    the exhaust might help it drop a tinny bit of boost, i know better rockers , ported heads, cam, extractors, ect all help drop the boost, the better ya motor is and flows the less boost you'll see on the gauge.
    join l67torque , theres shitloads of info on there about em
  1. [NSW] Wtb: Vt ultra lows and super super low springs
    By fatboy15 in forum Swap / Wanted to Buy / Trade
    Last Post: 30-05-2009, 02:52 AM
  2. [VIC] WTB: SC14 6PSI Pulley & 12Psi Pulley
    By Bz Kn33z in forum Swap / Wanted to Buy / Trade
    Last Post: 20-05-2009, 12:08 AM
  3. [VIC] vn vp front super low and rear super low king springs
    By tunsa in forum Parts And Other Items For Sale
    Last Post: 24-02-2009, 09:01 PM
  4. Pulley Tool for Super 6 in Brissy
    By Sweetas_VT_SS in forum General Discussion
    Last Post: 10-04-2007, 08:48 PM
