Results 1 to 16 of 16
Thread: V6 Ecotec Temperature
    Wagon
    Feb 2010
    Default V6 Ecotec Temperature
    Hey all,
    Had a few issues with my VT Commodore, V6 Ecotec engine overheating.
    Just out of curiosity, I would like to know where does everyone's V6 Ecotec temperature gauge sit at?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Half-way or if you read the digital temp on your dash, than ~91 degrees, what it should run at.
    Ronald Reagan (1986)
    Commodore M6
    Jul 2010
    East Coast
    diff engine but so far i've seen 90-107c or so... 90c is cruising speed in nov, when it was cold
    107 is in the middle of a heatwave with the air on
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Mine sits always on half way, no idea why it does though. Short trips or long trips always gets to half way then sits there, I would prefer it to be cooler but I think its probably because its not exactly made for Australian conditions like they used to be. Aussie cars used to be made to always run cool but these things warm them self up pretty quick.
    My VN always sits under 1/4 and if it gets to half then I think there would be problems although its never got that high.
    Best RPG ever
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Most sit just below half way at the hottest, as does mine. It's between 1/3 and 1/2 if that makes sense.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    VY SII HBD Calais L67
    Dec 2006
    By overheating do you mean you can hear the audible chime coming from the dash and the "HOT" word coming up in the cluster display? If it only happens shortly after cold start up (1st 10mins) it's most likely a sticky thermostat taking too long to open or if it's a longer intermittent overheating, intake minifold gaskets, heater tap or radiator could be the issue. All common well known issues to mechanics. Hopefully nothing major
    VYII Calais L67
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by chargedvx6 View Post
    Good question, or is it a more, "that's a fascinating smell" overheating.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    An engine runs at it's most efficient when hot, running temp is anywhere between 80-100 deg C, entirely normal. Gauges can vary anywhere from 1/3 to over 1/2. 107 is OK on a hot day with the aircon on.
    Visit my Facebook page
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    HAD MY VT FOR 14YRS (1ST OF THE 1997 VT,S TO COME OUT) its never ever gone past half even on 45C DAY
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    My temp needle always sits half way in between the 1/4 and the 1/2 way marks. Even on stinking hot days with air con on. The only time it has gone over was once when I tried to make a dash home after the top hose sprung a leak, (big mistake)
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    My VS sits on 1/4 when cruising, halfway give or take in traffic.
    My VP runs cold as according to the temp gauge. Will get to half way and kick the fan in sitting in traffic, but on the freeway it sits just above C.
    I think the thermostat might be stuck open...
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Boltonator_VT is offline Recreational User :)
    VT V6 Acclaim Auto
    Jun 2009
    Kumeu, Auckland
    Default Temp Gauge
    Mine used to be quite high, but after fixing the radiator, it now sits a little bit below a half. Sometimes on hot days where I go from 100kph to a crawl in traffic, it can start to rise but my fans kick in at 1/2 and it never goes above this.
    I never understood the sales of the Kia on the Holden lots here in NZ. I couldnt think of any cars that could be so different.
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    Thermostat opens at 91c (asuming it has a standard thermostat) & fans come on at 104c so in saying that it should never go higher or lower than that, every needle type gauge will be a little different from car to car so thats nothing to really go by
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Mine ALways Sits here on the Gauge, Never moves, When In diagnostic mode only seen it go to about 104° then the fans kick in and comes back down, Most Times always at 91°
  15. #15
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    if your concerned it's running too hot, tridon make a 81 degree thermostat. the part number is tt203-180. v6's standard thermostat opens at 95 degrees not 91.
  16. #16
    Wagon
    Feb 2010
    Well my cooling has got a new lower degree thermostat (81c), new water pump, flushed, pressure tested and new coolant over the period I have had the car. It now runs at around 80-95degrees so all is good! Thanks guys!
  1. VT temperature
    By Melissa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2010, 04:11 PM
  2. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  3. VT Temperature
    By 05LVQ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2007, 10:37 PM
  4. temperature
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2006, 02:16 PM
  5. Temperature
    By Flash_VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 06:40 PM
